Is there a histogram in Tuner pro that can be used to populate the LWFM table. Or can I make one using TP_REL, RPM AND LOAD_FG.
Histogram LWFM
Vince_m_97
- Vehicle Information: 1998 Mustang Gt
FHA3, CRAI8
4.6, 2v Trick flow heads, Forged internals
tr3650 5 speed conversion
Whipple 2.3 Saleen style, 12-15 lbs, cobra intake, JLT 4 inch tube
water/methanol inj.
47 lb injectors
stock 05 MAF
JBA mid length headers and mid pipe. No CATS
3.27 rear end gears
Re: Histogram LWFM
its already there
load is incorrect though its load error
the histogram populates the correction percentage
Vince_m_97
FHA3, CRAI8
water/methanol inj.
47 lb injectors
stock 05 MAF
3.27 rear end gears
Re: Histogram LWFM
That would be the N_TP_TOTLDSTerr histogram?
Vince_m_97
FHA3, CRAI8
water/methanol inj.
47 lb injectors
stock 05 MAF
3.27 rear end gears
Re: Histogram LWFM
And I multiply the values in the LWFM table by the ones in the histogram.
Forgive me but...
IM TRYIN!!
Forgive me but...
IM TRYIN!!
Re: Histogram LWFM
that all sounds right but im not at my laptop to verify
but yes the totldst error that populates in the histogram is the correction for the inferred load table. You multiply the current value in the table by the correction the histogram gives you.
I also have a newer adx that kicks out the actual lwfm table to copy and paste values as well but hadnt released it.
My GUFX strat I created a failed load table and have a specifically labelled GUFX histogram at the bottom of the list for those specifically if anyone is reading this with a fox ecu.
Best bet is to post in your actual strategy group thread so theres no confusion instead of using the range for strategy specific questions.
Vince_m_97
FHA3, CRAI8
water/methanol inj.
47 lb injectors
stock 05 MAF
3.27 rear end gears
Re: Histogram LWFM
Thanks you
