MicroSquirt® for 1986-93 Ford 5.0 Mustang?
Neald
- Vehicle Information: 1989 Ford Bronco II
Stock 2.9 V6, A4ld trans.
CBAZA(6CYL Config)
Moates quarterhorse
MicroSquirt® for 1986-93 Ford 5.0 Mustang? Or a later 96-04 pcm and repinned harness connector (104 pin?). Tuned with MongoosePro Ford?. Just asking for ideas and opinions on tuning life after Moates supply shutdown. Seems to be reality so time to move on . I'd like the idea of a factory ecm still and MAF. But microsquirt is fairly cheap, easy to install but is speed density..
Re: MicroSquirt® for 1986-93 Ford 5.0 Mustang?
Tweecer is another option, but not on TP IIRC.
Neald
CBAZA(6CYL Config)
Moates quarterhorse
Do they still make tweeker. That was pre QH If I recall.. I have a QH but my brother has an 89 gt getting a supercharger and supporting hardware that will need to be tuned.
Neald
CBAZA(6CYL Config)
Moates quarterhorse
I know I can tune his car with my QH and get a tune established, but there is no device available now to keep the tune with his ECM without leaving my QH on it and I can't do that. That's why I thought maybe a later ECM.. Like a 96+ ECM that can be written by a sct or some other type tuning device. But I'm not fluent in any of those. That's why I created this thread to get more ideas.
SCT 6600 is mentioned as an alernate chip...
http://www.efidynotuning.com/forum/view ... 9ad3#p9613
Neald
CBAZA(6CYL Config)
Moates quarterhorse
Yes. Thanks JSA. But how to write a tune to one without a Jaybird? Not available anymore.
Burn2 and FA are supposed write the same as jaybird, I've not used it.
https://www.poweraddersolutions.com/moa ... g-adapter/
https://www.hamotorsports.com/products/ ... mer-reader
SCT 7500 is the SCT burner, probably requires their software as well.
I've not used this either, you'd need to question them about suitability.
https://www.tiperformance.com.au/produc ... ammer-kit/
Neald
CBAZA(6CYL Config)
Moates quarterhorse
I was just going to bring up topic of the SCT 7500.. I'm wondering if it Really needs their software.. or if TunerproRt will work? I will check the burn 2 and FA as well. I thought the burn2 only burned chips removed from a board..?. I could be wrong. Is that a moates product?.
Neald
CBAZA(6CYL Config)
Moates quarterhorse
Oh nevermind. I see. I remember that now. The FA is a chip socket adapter to the f3 chip slot.. Got it!
034v
Neald wrote: ↑2022 Nov 27, 20:36 I was just going to bring up topic of the SCT 7500.. I'm wondering if it Really needs their software.. or if TunerproRt will work? I will check the burn 2 and FA as well. I thought the burn2 only burned chips removed from a board..?. I could be wrong. Is that a moates product?.
Yes the 7500 requires the PRP and won't communicate with TPRT
Burn2 FE/FA combo won't work on PRP either.
6600 works on both Burn2/FA/FE and JayBird
F3V2 won't work on 7500.
