Tune analysis
Covers most all fords in the 96/97 model year including but not limited to mustangs v6, v8, cobra, thunderbids, lincoln town car, grand marquis, crown vic and even some trucks and vans.
mlackke
Vehicle Information: Year: 1997
Make/Model: Ford Mustang Cobra SVT
Tune analysis
Unread post by mlackke »
Hello,
Wondering would this tune have something to improve, eg spark advance?
Car specs (not defined items are Ford Factory default):
VEHICLE YR/MAKE/MODEL: Ford Mustang Cobra SVT 1997
PRIMARY VEHICLE USE: daily
__________________________________________________________
INJECTOR SIZE: 60
INJECTOR BRAND: Siemens Deka
INJECTOR COLOR: Black
FUEL SYSTEM TYPE [STOCK,RETURN,RETURNLESS]: RETURN
ADJUSTABLE FUEL PRESSURE REGULATOR [Y,N]: N
BASE FUEL PRESSURE: Ford Factory Default
FUEL PUMP QUANTITY & SIZE [LPH]: One Aeromotive 11540 Fuel Pump (340 Series)
FUEL TYPE OCTANE & GRADE: E98
FUEL RON/MON (for non-USA countries): 98.8 RON
ENGINE BLOCK SPECS: Ford 4.6 DOCH
COMPRESSION RATIO: 8.5:1
APPROX. HOW MANY MILES ON ENGINE?: 5000
PISTON SPECS (include GAP if known): Manley 4.6L Forged Alloy Pistons (GAP bore x .0055")
ROD SPECS: (include if ARP bolts): Manley 15042R-8 Ford 4.6L / ARP2000
Fully Forged Rotating Assembly ?: Y
BILLET OIL PUMP GEARS [Y,N]: Y
POWER ADDER TYPE [Turbo,SC,n2o]: SC
TURBO/SC MAKE/MODEL#: Kenne Bell
#s BOOST MAXIMUM: 10 psi
BOOST CONTROLLER PRESENT [Y,N]: N
BOV/BYPASS LOCATED BEFORE OR AFTER MAF?: After
LIST ANY ADDITIONAL POWER ADDER DETAILS: intercooled
COOLANT THERMOSTAT TEMP: 180f
AIR CHARGE TEMP SENSOR LOCATION: Lower Intake
MASS AIR FLOW SENSOR TYPE: SCT BA3000
MAF/INLET PIPING SIZE: CAI2-FMC-9698
INTAKE MANIFOLD SPECS: Custom made
LIST ANY ADDITIONAL INTAKE SPECS: Custom made intake for KB
Base Tune 7_29_20.mtf
(240.68 KiB) Downloaded 967 times
Re: Tune analysis
injectors are clipped
you need to put the accurate injector data in, read the fuel write up for specifics
You shouldn't list E98 for fuel its actually 98 E5 fuel major difference, americans will get that significantly mixed up.
It doesn't look like anything in the tune is dialed in and certainly not spark
mlackke
Re: Tune analysis
Thanks for info already, i will check fuel write up.
Can you elaborate this?
Re: Tune analysis
decipha wrote: ↑2022 Sep 26, 04:15 ... read the fuel write up for specifics
