Datalogging Patch Error?
Justin Jones
Vehicle Information: 1991 Ford Mustang LX 5.0 A9L Explorer Intake - Moss Ported, 70mm TB, 90mm Lightning MAF, 30 Lb injectors, GT40X heads, FTI cam 214/224 .600 1.7 rockers. 10:1 compression.
wbo2_innov_mtx-l
Re: Datalogging Patch Error?
Unread post by Justin Jones »
Here is the last tune I received. I have not loaded it yet and ran it. I also have the WOT and cruise datalogs from Tune 11, which is prior to this one.
A9L Justin_12.BIN
(56 KiB) Downloaded 552 times
that's not a bad tune but there's a lot that can be improved upon
I copied over the fuel model to a base a9l2 tune as everything else doesn't copy the same.
This should get you started.
best bet for a replacement stock distributor is the u pull it yard
justin_1.bin
(56 KiB) Downloaded 535 times
Justin Jones
wbo2_innov_mtx-l
Thanks. I guess I don't have the TP setup right even after following your directions and double checking them. Because after downloading the BIN, when I double click on it, it won't automatically load. I suppose no matter because I can go in under File and "Open BIN"?
