first start
Tuning for alternate fuels such as: CNG / LPG, Ethanol (E-85), Methanol, etc...
first start
Unread postby g3mustang » Mon Nov 24, 2014 11:06 am
so im building a 393 stroker with e85.
this is my first engine build and motor break in. How do i not wash my rings out and break it in when first tuning it?
g3mustang
Supporting Member
Vehicle Information: 393 s475 b/w turbo 9:1 compresion 185 afr heads c4 trans a9l2 tunning with BE e85
331 180 heads, cobra intake, 50lb injec., cobra maf, anderson cam
Re: first start
Unread postby decipha » Mon Nov 24, 2014 2:42 pm
get into closed loop ASAP
I usually force closed loop as soon as the hegos report rich, you do that by:
set the "minimum hego switches required to allow closed loop" scalar to 0
and set all closed loop delay scalar (warm hego delay) to 30 seconds, make sure the hegos come alive after that 30 seconds or it'll just dump fuel to get the hegos to switch
once she gets into closed loop, wait for her to get to warm stable idle
while its warming up its a good idea to look over the engine and make sure theres no leaks, etc..., check the tire pressure as well if you hadn't already and get her ready to go for a cruise
once shes up to warm idle, go ahead and unplug the tps sensor (if you need to open the blade) and approximate how much you need to adjust the throttle screw based on the value of IPSIBR, if IPSIBR is 0 and your closed to dsdrpm then no worries
work the mafv from idle up to 6k redline and dial in the fuel
apply the highest fuel correction you can reach to all the flows above that maf voltage too
next if you hadn't already set the fuel table for e85, subtract 0.05 from the top 3 rows (90, 105 and 120 perload) that should have you demanding .75 at 120 perload and .825 at the 90 and 105 perload in the base fuel table
then drive her and try to reach the next mafv point in the maf curve that you couldn't reach free revving it, watch the lambse and wideband and dial it in, then repeat this again reaching the next mafv point, so on and so forth until you've got it all dialed in
let me know if you need clarification on any of this
the step1 write up can give you more details as for as what needs to be done
http://info.efidynotuning.com/step1.htm
Re: first start
Unread postby g3mustang » Mon Nov 24, 2014 4:06 pm
thanks for the help im really scared that i wash my rings lol so i wanted to make sure i have all the info i need to get ready not to flood it.
g3mustang
Supporting Member
Re: first start
Unread postby decipha » Mon Nov 24, 2014 4:18 pm
you know what your doing gary no worries
only uninformed people wash down cylinders
Re: first start
Unread postby g3mustang » Tue Nov 25, 2014 8:16 pm
Thanks for the confidence lol I wish I had more friends that would let me tune there cars so I can practice while my cars down lol
g3mustang
Supporting Member
Re: first start
Unread postby decipha » Tue Nov 25, 2014 10:49 pm
where are you located?
post a thread asking someone to post a datalog for a free tune
Re: first start
Unread postby g3mustang » Wed Nov 26, 2014 11:15 am
im in springfield mo.
im scared to post that i can tune im not as fast as others are. lol
g3mustang
Supporting Member
Re: first start
Unread postby decipha » Wed Nov 26, 2014 1:45 pm
don't be scared, its free right? you only offering support, plus anyone else that does DIY tuning will have a grasp of whats going on
plus im here to check it out with yall too
go for it
Re: first start
Unread postby cobraclone393 » Wed May 13, 2015 3:52 pm
i have a 393 with e85 hope this can help, the 05 slot maf is in a 4" pipe. should start for you at least.
cobraclone393
Vehicle Information: 393,12.1:1,vic jr heads heavy porting,vic jr "spider" intake,80lb deka,1.6rr,90mm accufab tb,05 slot 4" pipe,BE, quarter horse, mac 351w swap 1-3/4 lt, mac header back, a1000 pump and reg, a9l,91wiring and 91 car,full msd ignition,comp cams 35-776-8 duration (.050)248 258 duration 304 314 lift .608 .608 130a alt,3800 stall full man rev c4, 3.73. AEM wideband tied into BE. E85-70
Re: first start
Unread postby decipha » Wed May 13, 2015 3:57 pm
welcome to the forum
and look at that first post your posting up a tune
your gonna fit right in lol
Re: first start
Unread postby g3mustang » Thu May 14, 2015 8:32 am
thanks for that ill look it over
g3mustang
Supporting Member
Re: first start
Unread postby g3mustang » Thu May 14, 2015 12:26 pm
cobraclone393 wrote:i have a 393 with e85 hope this can help, the 05 slot maf is in a 4" pipe. should start for you at least.
I see you changed alot of the original fuel scalars. would you happen to know which ones were most beneficial? I'm a novices so i just start with the A9l2 tune and work whats only in writing.
g3mustang
Supporting Member
Re: first start
Unread postby cobraclone393 » Thu May 14, 2015 8:09 pm
the tune started life as a early form of a9l2, it has since changed. the start up fuel is due to e85 and 80lb injectors. the base fuel table is set up for e85 and is a great starting point. i do have a 90mm tb so you may or may not need to change a lot in the idle air department. you will need to dial in your fuel using your mass air transfer. then you can work on the idle. what size injectors are you running. also my timing is for aggressive NA. i would think you should use what is in the base a9l2 due to boost. my idle is set for 1000 rpm due to the cam. so first i would put in your injector parameters, then move over to the mass air transfer, dial your fuel in so commanded is what you actually get on your wide-band (do some searching or read the info from the main screen as how to do this). then work on the idle. you may or may not have little things to work on after that but this will get you up and going quickly. oh and a tip, if its cold below 60 out when you start the engine it may a die once or twice with e85, you get used to it. i'm working this aspect of my tune right now.
cobraclone393
Re: first start
Unread postby decipha » Thu May 14, 2015 10:00 pm
when cold kick up the isc multiplier
best bet is to start from the A9L2 and go through the write up
then for e85 theres only 5 things u need to do
1> shoot MBT to it
2> kick up the crank pw *1.25
3> drop the top 3 rows of the fuel table by 0.05 lambda
0.875 = 0.825
0.800 = 0.750
4> kick up FN035 Peak Load Scaling where the engine makes more powah / Load
5> set stoich fuel scalar to e85
amd thats it, dial it on in like u would otherwise
Return to Alternate Fuel Tuning
