changing stoich AFR to 14.64?
canuck1
Vehicle Information: QH, TunerPro RT 5, GUFX_220418.xdf, A9L2_220405, DECIPHA_220505.ADX, 395w, AFR 195CC Renegade heads, Comp XE274HR cam, Siemens-Deka V 80lb/hr (shorties), Mass-Flo-EFI style 4bbl throttle body with GM maf on top. Custom long tube headers, sidepipes, 5 spd manual.
Unread post by canuck1 »
A9L2 uses a stoich AFR setting of 14.079:1. Where I fill up, the premium fuel is labelled "NO ethanol". Do you think that's a valid enough reason for me to change my stoich AFR to 14.64:1? Any precautions I should be aware of?
Sean
Re: changing stoich AFR to 14.64?
yep you should always put the most accurate info in your tune
go ahead and change it no prob
