EEC-V wiring diagram?
Re: EEC-V wiring diagram?
Unread post by dleach1407 »
AcesArneson wrote: ↑2022 Jun 25, 16:10 Thanks for the reply but I could not open it, said it was not found. Any chance you can attach it another way?
https://64bittuning.fwscart.com/Ford_Sm ... 26462.aspx
AcesArneson
Unread post by AcesArneson »
Thank you, I looked at these guys but they don't supply the AR kit. Looking at their package it doesn't really seem that complicated. I will likely get what I can from them. Also sounds like 96-97 F series trucks may have AR Sensors and reluctor wheels on the balancer, so I might look for one in the junk yard to see if I can salvage the wiring harness, mounts and reluctor wheel.
