computer not controlling timing
canuck1
Vehicle Information: QH, TunerPro RT 5, GUFX_220418.xdf, A9L2_220405, DECIPHA_220505.ADX, 395w, AFR 195CC Renegade heads, Comp XE274HR cam, Siemens-Deka V 80lb/hr (shorties), Mass-Flo-EFI style 4bbl throttle body with GM maf on top. Custom long tube headers, sidepipes, 5 spd manual.
Unread post by canuck1 »
I have fired my car back up after replacing distributor pickup/Hall effect sensor AND TFI module. Checked spark and coil control, everything appeared OK. Starts and runs fine but SAFTOT is displaying a single value kind of like if the spout were disconnected (it seems stuck on 14 dbtc). The spout connector seems OK, any idea what this points to? Maybe an issue with my logging setup in the latest TunerPro RT?
Sean
Re: computer not controlling timing
the ecu isn't logging the actual spark its only logging what its commanding. It has no way of knowing if the spout is in or out.
canuck1
Thanks. Is there a chance I’ve enabled/disabled advance/retard (computer control) in my BIN inadvertently?
What is the purpose of the flag ‘Allow spout test” etc.?
Sean
canuck1
Just to follow up. I’m not sure whether the difference was installing the latest version of A9L2 and overwriting an error in my earlier bin or maybe using an older (modified) ADX but all seems normal now.
Sean
