BE to Decipha Translation?
Re: BE to Decipha Translation?
what strategy are you using?
whats the setup?
TP or BE will only have FN's if the author of the definitions includes them.
decipha wrote: ↑2022 May 26, 17:04 what strategy are you using?
AGANN/YER2.
decipha wrote: ↑2022 May 26, 17:04 whats the setup?
That's for a 1996 California-spec 460 with EEC-V, MAF, SEFI, and manual transmission.
Answering for the OP.
I use AGANF on those.
Gary Lewis
Vehicle Information: 1985 F250 w/a Scotty-built 460, EEC-V, ZF5, etc. No EGR or cannister purge.
ECU is a YAZ3/ML1-441 & I'm using AGANN/YER2. Programmed via BE & MongoosePro Ford.
Unread post by Gary Lewis »
Guys - I'm sorry I've missed the questions and answers. I had ticked the " Notify me when a reply is posted" box but didn't think I was getting email notifications. However I just found them in the spam folder and corrected that. Sorry! I feel really embarrassed as I run a forum so thought I know how these things work.
But wwhite is right, I'm using AGANN/YER2 and the ECU has a catchword of YAZ3 and that is an ML1-441. The engine is a Scotty-built 460 w/a ZF5 and EEC-V with MAF & SEFI so it fits that well. I've worked with Core Tuning and have gotten the system running quite well, but there are things that I want to improve, like the idle. I've been reading the how-to on that on this site and think I could follow it - if I understood which scalars and functions are which.
Dechipa - I don't know what services you offer. But I've purchased Binary Editor and one token plus the Mongoose Pro cable, so I'm into Core Tuning for quite a few dollars. I am making progress on the tune but have a few issues I want to sort. I do have an idle that is too high, running around 800 RPM warm when I've told it to run at 648. And I'm working on what Core Tuning calls the Idle Air Adder for ECT table to get the warmup sorted. Plus I'd like to add a bit more timing.
So I would appreciate your guidance.
unfortunately i cant do anything with BE I use tunerpro for everything
Gary Lewis
Ok, thanks. And since I don't have nor use Tunerpro, ne'er the twain shall meet. But I'll still be reading your directions since they are very informative and helpful, and trying to decipher which BE parameter you are talking about. May come back with more questions, but realize that I may not get answers.
Unread post by dleach1407 »
Tprt is free...
Gary Lewis
Tprt?
Tuner pro rt
