FBFG2 strategy?
Re: FBFG2 strategy?
attached
if she still acts up then one of the DTKS scalars is affecting it.
Best bet would be to load your file back in and do a compare against the file I posted above then copy over each DTKS emulating one at a time til she acts up so you know exactly which one it is. If thats the case.
Cougar281
2002 PI 4.6L V8
1999 J-Modded 4R70W
2004 PTP2 PCM
Re: FBFG2 strategy?
Unread post by Cougar281 »
No dice. With that file, no fuel pump at all, even changing RF_DC_CAL and MFP_PERIOD. If you're scripting the file I sent, maybe there's some tomfoolery embedded somewhere inside... maybe scripting a bone stock read (attached) might work better?
PTP2_STOCK_READ.bin
(256 KiB) Downloaded 121 times
Re: FBFG2 strategy?
see post above you ^^
Re: FBFG2 strategy?
attached
Cougar281
2002 PI 4.6L V8
1999 J-Modded 4R70W
2004 PTP2 PCM
Re: FBFG2 strategy?
Awesome! That last one seems to be on the right track. Fuel pump is acting the same as the modified MGZT tune. But so I can learn (and I apologize, I apparently missed the additional info in your previous post), what is 'DTKS'? When I search the tune for that, it comes up with nothing. But it does seem to start and idle differently from the PTP2/FBFG2 tune I've been running. Now that I have a working FBGI0 'base', I'll have to see if I can figure the rest out. The different start/idle could be as simple as a MAF scaler difference.
Re: FBFG2 strategy?
try v2b posted above u never downloaded it to verify
Cougar281
2002 PI 4.6L V8
1999 J-Modded 4R70W
2004 PTP2 PCM
Re: FBFG2 strategy?
decipha wrote: 2022 May 05, 21:05 try v2b posted above u never downloaded it to verify
Yes I did, not sure why it says I didn't. That's the one that I was referring to in my post at 19:58 (central time).
Re: FBFG2 strategy?
that means u downloaded thebwrong file go ahead and give it another download and try
Cougar281
2002 PI 4.6L V8
1999 J-Modded 4R70W
2004 PTP2 PCM
Re: FBFG2 strategy?
No, the 'Cougar281_ptp2_v2b_dtks.bin' file you posted at 19:46 Central is the one I downloaded, and it's working pretty much exactly like the MGZT file with the fuel pump modifications. Which is good. I'll just have to try to figure out why the start/idle is different from the PTP2/FBFG2 tune - could be a MAF scaler or something as earlier today, when I was looking at my original PTP2 and the MGZT tunes, the MAF scalers did seem to be different. Not by a ton, but it could be enough.
Re: FBFG2 strategy?
thats not it
9 posts up
