trying to dial this tune in. could some one check it over please
- Vehicle Information: 2015 5.0 from F150
2016 mustang pcm strategy FPGP6KS
2.9 whipple
132mm whipple throttle body
1050X injector dynamics
fore dual fuel pumps with return fuel lines
long tube headers
91 octane
2013 F150 3.5 ecoboost
2006 F350 6.0 Powerstroke
87 mustang 5.0 automatic. Converted to MAF, PCM A9M, ford orange 19lbs injectors, stock maf and housing. Suppose to have a Ford racing E303 cam.
I have a wideband in the exhaust but is not wired to pcm for logging.
Getting the MAF dialed in. adjusted ISC gain for hunting idle when hot start.
A big issue this car was having. when shifting into drive or reverse and when coming to a stop. the brakes would have to be applied very hard to keep the car moving. I've gotten it to do better. Wondering if there is anything I can do.
Re: trying to dial this tune in. could some one check it over please
Hunting idle on hot start wouldn't be the isc gain it would be the target isc duty cycle table. Simple kick it up to get the rpm to dsdrpm. If dsdrpm is too low then the dsdrpm needs to be kicked up.
Your using the wrong adx file its severely outdated and not logging correctly. Where did you get it ? Download the latest files from the downloads here.
Otherwise you have a 10% global fuel correction. She looks stock.
btw you don't have to compress bin for xdl files as they are already compressed
- jcbryant_autofox.bin
- (56 KiB) Downloaded 261 times
2.9 whipple
long tube headers
91 octane
Thank you
I’ll work on the desired rpm once I get the Maf closer
I got the adx from here
viewtopic.php?t=18
Thanks for info on the bin and xdf being compressed.
viewtopic.php?t=18
i just posted some new files but im thinking it might not be logging correctly if you don't have the latest version of tunerpro
snatch the new files just in case though, adx and xdf
2.9 whipple
long tube headers
91 octane
Used the Bin jcbryant autofox bin you posted. Also went and downloaded the ADL and XDF files again.
cars is running great. Had to tweak the maf at idle a little. Fuel error looks to be under 5%. Car runs great. getting ready to check cold start.
Were the issues all software related or did I have some things wrong?
Thank you. I really appreciate all your help. It can be very complicated but I'm learning a lot.
neither
she just needed a 10% global correction was all.
Biggest change was probably setting it for an automatic so it uses the neutral target iscdc table and swaps to my custom drive target iscdc table when thrown in gear to make the transition much more stable
2.9 whipple
long tube headers
91 octane
I was looking over the switches for auto but I thought I saw it was not recommended in the description. obviously read wrong. Ill look to see what you did. Thanks again.
yeah it wasnt back in the day i probably need to update the comments
2.9 whipple
long tube headers
91 octane
I've got this car back again. Customer did a bunch of work on resealing intake manifolds and said he fixed vacuum leaks. He installed new 24lb injectors that are suppose to be foxy body cobra 24lbs injectors. injectors did not look correct. Only marking on injector was 250cc.
He also installed PMAS MAF MH80B-1800.
I put in the data for the maf. I tried several 24lb injector data but could not get lambda to hold what I was trying to command.
I removed the 24lbs injectors and installed a set of bosch 19 EV6 using data from your site. I still can not get lambda to correct. Now it is running very rich.
attached is tune file and log at idle I have a wide band wired in this time
Are the injector wires good?
