351W with broken rod
Re: 351W with broken rod
yeah id keep the cam. Might as well keep the lifters if your keeping the cam just mark where each one goes and its orientation so they go back in same as they came out.
unless theyre damaged or your upping the compression no need in replacing the pistons
why are you machining the block or replacing the crank?
if budget is your objective why not just pull it down and inspect it? if all is well just pass a ball hone through it and re assemble with new bearings and rings and done.
id score a set of early gt40 heads if you can.
Thanks for the info. Yeah the inspection failed on bearings and a crank main was scored. Rod bearings were down to the copper. I didn't plan on going in this deep but it is cheap insurance getting a good crank.
I like your idea of reusing the pistons. The hyper pistons with coated skirt are only $16 for 30 thou over so that what I was thinking. $250 for the block work and hot tank but I'll think about just doing the minimum you suggested. I kept locations of lifters but didn't mark orientation, am I up a creek?
I'll see if I can find GT40 heads. Do they have smog ports in the rear?
dont bore it anymore than u have to
250 is definitely lacking, i charge 650 to machine a block and at that i make almost no profit
nah lifters should be ok
yes they do
These are in my area. What do you think? How much better than stock are these?
https://www.ebay.com/itm/1987-1995-Ford ... 632-2357-0
garbage, no such thing as gt40p cobra heads either but way too over priced
I'm not seeing anything cheaper than that. What new head would you recommend? Would be nice to keep pedestal mount rockers for simplicity. I'm not racing or anything.
I would recommend the RHS heads
Unread post by red5.0fogger »
You won't regret buying good quality cylinder heads. If you don't have boost or nitrous good heads are the only way the engine can breath. They make a huge difference. Going from the worst head (the 86) to a nice flowing head, the Trick flow 170 gave me 100 HP increase.
Yeah, I can't see putting the motor back in without at least reworking the stock heads, which would cost about half as much as aftermarket heads. Being in California I have limited options though. The Edelbrock 50 state legal heads are not available but it looks like I could get a pair of afrs for around 2K. I didn't look extensively into trickflow but do they have emissions complaint heads?
Another curve ball is, after further inspection this camshaft has some pitting on one of the lobes. I believe the motor that I pulled out has a roller cam so I'm going to inspect that one hopefully it's good enough to use. If not it doesn't appear that cams are readily available right now.
