02 v6 Mustang to 5.4 4v twin turbo
5.4DOHCTurbo
- Vehicle Information: 02 Mustang v6. Swapped to 5.4L 4v with Twin turbo. Navi stock heads, H connecting rods. Piston is .03 oversized. Using MDE3 ECM
5.4DOHCTurbo
Re: 02 v6 Mustang to 5.4 4v twin turbo
old build pics. I will send pics of the engine completed
5.4DOHCTurbo
New pics of my budget build. Let me know what you think
Your first post says youre using a .030 over block with stock pistions. As you already stated, youre going to have to get pistons so your first post isnt accurate. I think thats the point they were making.5.4DOHCTurbo wrote: ↑2022 Mar 22, 23:27 All stock pistons are standard size. If block is over bored, then you obviously you get pistons to match.
5.4DOHCTurbo
I understand. I meant to say is piston is factory and no high performance brand, but of course sized up for the .030 over bore block.
Any updates on the build?
