your already upgraded
when your info comes through youll get your own thread over there
Looking for tuning help on 1996 Bronco AGANF
OldBroncoRacer
- Vehicle Information: 1996 F150 4X4 PreRunner 418W 270 Cam EWPI Heads SpeedMaster 5.8L Mustang 75mm Intake FTPF-AWA ZJT0 AGANNE9 ML1-441 4.86's 35X12:50-15's
2001 Ranger Desert Racer 408W XE282-HR Cam Full Manual 4R70W AFR's Pro-M Intake etc Crown Vic PCM
Re: Looking for tuning help on 1996 Bronco
If you haven't figured it out yet, it's behind the E-brake, and access to it is from the engine compartment, so the easiest is to remove the drivers front tire, then the inner liner, get a mirror, and read the label. Kind of a pain. Maybe just go to Autozone, Oreillys, or someone with a code reader - it might tell you.
-ed
TexasA&M
- Vehicle Information: 1996 Bronco
427 Stroker
GT40 Heads
Trickflow Cam
Edlebrock Intake
Bassini Shorty Headers
30lb injectors
Pro-M MAF
I pulled it out last week and read it. Wasn't terribly difficult, but I wouldn't want to do it regularly. Good call on using a code reader... the SCT I'm using to tune/datalog tells me the strategy. I think I would have had to still pull the computer to verify the hardware code though.
Yeah always best to yank the ecu to see the actual hardware code as its not too uncommon for ecu's to get strategy swapped.
