Cooke, Brian (68 Bronco)
Attached startup tune.
Open your throttle stop by about 1/2 of a full turn first, load this in and shoot me back a step 1 log.
http://www.efidynotuning.com/step1.htm
BCOO_220203a_startup.bin
(56 KiB) Downloaded 2299 times
Re: Cooke, Brian (68 Bronco)
nvrstuk wrote: 2022 Feb 09, 21:14 Can I take the tune you just sent me, open up TunerRT and load it, then connect my laptop to my Qtrhorse and download it?
I might need help walking thru this the first time, then I'll be good. thanks
I do not have NSS connected and want to remove my current A9l and replace with one of my A9P's as I want to sell the A9l and just run one model of ECU with my 2 vehicles that have 89-93 ECU's.
You have to upload it not download it but yes thats correct.
details are in the getting started write up
A9L amd A9P are all the same u can swap it no prob
nvrstuk
Vehicle Information: '68 Ford Bronco
A9l, Moates Qtrhorse
WOT only - 92uego
Unread post by nvrstuk »
Ok...put 2 1/2 hrs into loading g chips but we got TunerRT to datalog a couple long tunes. Wouldn't start but followed your instructions for holding the throttle wide open and eventually started.. Yeah!! Freaking excited.
Problem is the datalog is NOT on my new laptop. On my buddy's.
He is going to sign up for Premium as I am the guinea pig.
Can we somehow transfer the datalog or let him download it to your site?
nvrstuk
WOT only - 92uego
My laptop still cannot show a dashboard! I can't datalog w/o the dashboard...
Every have a problem like this?
No never.
Yeah no problem just lmk his username and ill upgrade him.
nvrstuk
WOT only - 92uego
thanks Here's his username
rocknhorse76
thats the tune file i need the actual xdl log file
if need be call me on my mobile 504-606-0532
rocknhorse76
Vehicle Information: 1976 Ford Bronco
351W
A9P ECU
EDIS
Unread post by rocknhorse76 »
Apparently they didn't save to my computer. Brian will have to make one tonight.
nvrstuk
WOT only - 92uego
I will have my Bronco running before noon PST. I am excited to get you a couple datalogs and get this baby running sweet!
yep no prob whenever you can get to it no rush i'll be here
