[CBAZA] Strategy Files
Locked
^^Subscribe to this thread so you are alerted when updates are posted^^
CBAZA is the strategy for all 94-95 mustang V8's both auto and manual as can be used as well for 94-95 F-150 V8's with clock speed ref patch.
U4P2 is the decipha modified stock 94-95 automatic v8 mustang gt tune file for premium fuel.
T4M2 is the decipha modified stock 94-95 manual v8 mustang gt tune file for premium fuel.
HUG3 is the decipha modified stock 94-95 automatic v8 F-150 tune file for premium fuel.
DECIPHA_250126.adx
cbaza already selected
(492.13 KiB) Downloaded 868 times
CBAZA_240216.xdf
POSTED 25-02-23, old file was from 2021 !!! not sure how much has changed since then but im sure ALOT.
(795.54 KiB) Downloaded 910 times
FCL0_Stock.bin
94/95 GT Auto - W4H0 Low Power Mode
(56 KiB) Downloaded 1475 times
J4J1_Stock.bin
94/95 Cobra GT40 Heads/Intake 24lb Inj w/ tbird cam
(56 KiB) Downloaded 2668 times
L4C1_Stock.bin
94/95 GT Manual - No Emissions and no HEGOs Cal for non USA vehicles.
(56 KiB) Downloaded 1472 times
S4M1_Stock.bin
94/95 GT Auto AODE - W4H0 No Emissions and no HEGOs Cal for non USA vehicles. 2.73 rear gear
(56 KiB) Downloaded 1447 times
U4P0_Stock.bin
94/95 GT Auto AODE - USA (3.08) 3.27 rear gear
(56 KiB) Downloaded 1506 times
W4H0_Stock.bin
94/95 GT Auto AODE - USA 2.73 rear gear
(56 KiB) Downloaded 1454 times
ZA0_Stock.bin
95 Cobra R 351w (svt's garbage file) 3.27 rear gear
(56 KiB) Downloaded 1509 times
T4M0_Stock.bin
94/95 GT Manual - USA
(56 KiB) Downloaded 1537 times
FOX_SWAPPED_210514.bin
using fox harness and cbaza swap instructions
(56 KiB) Downloaded 1483 times
U4P2_210514.bin
AUTOMATIC AODE/4R70W/4R75
High Performance
(56 KiB) Downloaded 1644 times
T4M2_210514.bin
MANUAL TRANS
High Performance
(56 KiB) Downloaded 1720 times
Re: [CBAZA] Strategy Files
T4M2 attached.
u4p2 and updated t4m2 attached
stock tune files and notes added
posted hug3 stock tune file as well as updated xdf and adx. Nothing should be different logging wise but the older xdf and adx were from 2021 some 4 years ago. I'm sure alot has been updated/changed since then although nothing critical.
posted updated hug3 file with TCSHP corrected so TCIL functions correctly.
main differences between f150 and mustang
1 hego
tcs is led and not a bulb hptcs=2
4r70w vs aode 1st gear ratio
major update for cbaz0 folks
cbaz0 has a different clock speed and will require enabling the clock ref patch
Locked
