So, I was able to unify the 2.3 and 4.0 strategy under the MA35C board family. These two have some small differences but everything else matches.
I utilized the "visibility level" feature built into TunerPro to expose the necessary differences. Datalogging should work on the 4.0 with Decipha's 11/9/17 ADX that I provided. I will get around to updating the patch code eventually, but I know this works fine.
"Show All" does just that. It looks chaotic.
"Level 1" visibility is for the 2.3 specific stuff.
"Level 2" exposes the 4.0 stuff.
I built this around m0m2 and X0A respectivelty. The 3.0 "X1L" is far too different, and I'm working on a strategy for that.
[MA35C] 90-92 Ford Ranger 2.3 and 4.0
motorhead1991
- Vehicle Information: 1990 Ford Ranger commercial:
1990 Ford Ranger Custom:
- MA35C_public_12-11-21.zip
- (256.69 KiB) Downloaded 735 times
tufgriz
- Vehicle Information: 1993 4.0 Ranger xl Currently stock RAT1
1989 mustang gt running Megasquirt HCI 302 swapped back to a9l
Re: [MA35C] 90-92 Ford Ranger 2.3 and 4.0
any luck on a 1993 ranger RAT1 with I believe Strategy W2E1 Havent been able to find anything anywhere as of yet
motorhead1991
I don't have that one, but I do have one for a 94. I can't remember which bin it was though.
EDIT: upon further digging, I believe I only have the 2.3 and 3.0 bins if that vintage. If you can get me a copy of your ECU I could probably whip something up.
