Can the lightning .bin files(C3P1,C3P2,C3P3,ICY1) over on eec analyzer under LHBL0 be used with the A1C.xdf and decipha.adx?
I have the c3p2.bin from there loaded into TunerProRT but it doesnt look like the numbers make sense
http://www.eecanalyzer.net/strategies
Lightning bin files
s74p13s
- Vehicle Information: 1984 EFI Swap Ford Bronco U2L1 EFI-SD48B.5.8 lightning clone engine. GT40 Heads,Edelbrock Intake,Exhaust,Comp Cams 35-255-5
Re: Lightning bin files
Nope, you cannot. Different layout in the bin, nothing will make sense.
You have the following options:
1- use A1C.bin with A1C.xdf and decipha.adx
2- find the old 2017/2018 adx DECIPHA_EEC-V_QH_20171109.zip with the xdf EFI-SD4X_180125.zip, and use C3P2 (lightning bin).
3- roll your own
With my build, I could never get A1C running correctly, the old C3P2 stuff never ran properly on my engine, so I ended up creating my own adx/xdf for my KID2.
Looks like http://eecanalyzer.net/strategies has U2L1 already broken out a little.
3- roll your own
I posted a 6 cyl and a stock v8 file
s74p13s
Awesome thanks for the bin decipha.
I also have the old adx and xdf for the c3p2 so that gives me a couple options to work with. Thanks guys!
