Anyone using RSAZA on a pushrod 302?
91GTman
Vehicle Information: 1991 Ford Mustang GT
A9L - BE/EA
Unread post by 91GTman »
Looking for pics/info on how you mounted/located the coils
Re: Anyone using RSAZA on a pushrod 302?
Yes, i am. You can mount them anywhere. I plan on putting them on the valve cover and using ls wires. You could mount them on the firewall and build custom plug wires too.
91GTman
A9L - BE/EA
Awesome, do you plan on using oem coils? How far off are you from doing the coils on your build? Having a hard time finding pics of ford coils mounted on a pushrod 302
I'm an using 2v coils since they have a mount hole. I'm building a bracket to weld directly to the valve cover to hold them. You won't find pictures of them most likely. It's not common. I'm still a ways off on that. I'm still messing with the air bag suspension but i already have the ecu wiring roughed in.
Unread post by RinerAuto »
I'm in the planning phase right now. I have the engine harness and ECU. The plan is to complete it over winter off season and get it running/tuned early spring. I'm also thinking a bracket on the valve covers is the best option for mounting the coils.
I'm about to build a press brake so i can bend up the bracket. I'm still collecting parts but I'm really close to getting it running. I should have it running before the end of the year. I have so much to do on the truck, It's overwhelming so i lost interest for a bit this summer.
dleach1407 wrote: ↑2021 Sep 19, 01:35 I'm about to build a press brake so i can bend up the bracket. I'm still collecting parts but I'm really close to getting it running. I should have it running before the end of the year. I have so much to do on the truck, It's overwhelming so i lost interest for a bit this summer.
Definitely been there. I have a 4runner that's been sitting waiting on an engine swap.
I'd be interested in see the brackets you come up with. I'm debating trying to do bolt on to valve cover bolts, or welding on bolt pads on top of valve cover, or through bolts on top of valve cover.
91GTman
A9L - BE/EA
Also needing to figure out how to mount the crank sensor. I have the stock sensor from a 04 marquis. I have an aftermarket pioneer balancer that is balanced with the motor so I don’t want to swap for the explorer timing cover set up. I have a 36-1 wheel I can’t mount behind the crank pulley. Guess I’ll have to fab a bracket and use some shims for gapping the sensor.
waltnono
Vehicle Information: 1995 Mustang V8 Swap
WH40
76mm Turbo
4r70W
wbo2-uego
Unread post by waltnono »
91GTman wrote: ↑2021 Nov 06, 23:42 Also needing to figure out how to mount the crank sensor. I have the stock sensor from a 04 marquis. I have an aftermarket pioneer balancer that is balanced with the motor so I don’t want to swap for the explorer timing cover set up. I have a 36-1 wheel I can’t mount behind the crank pulley. Guess I’ll have to fab a bracket and use some shims for gapping the sensor.
I'm in the planning stage of doing the same thing for my SN95. Its easy for me to use the explorer timing cover because its basically the same as 94-95 mustangs. I was going to order this trigger wheel.
https://64bittuning.fwscart.com/Ford_Sm ... 26462.aspx
I've done quite a few of them. There's currently a premium member that has a sbf gt40 302 in a ranger with one as well.
LMK when any of yall are ready and I'll post an updated xdf with my new ect code and a base sbf manual trans tune as well to make life significantly easier.
