Here is the MTF file I was sent by kenne Bell for this car originally. When I loaded this in the car a year ago to try and turn traction control back on it set the Engine Fail Safe Mode.
2008 Super Snake Failsafe Engine Mode
jcbryant
- Vehicle Information: 2015 5.0 from F150
2.9 whipple
132mm whipple throttle body
1050X injector dynamics
long tube headers
91 octane
2013 F150 3.5 ecoboost
2006 F350 6.0 Powerstroke
Re: 2008 Super Snake Failsafe Engine Mode
Load the file in i posted and see if it still sets an etc fault
jcbryant
2.9 whipple
long tube headers
91 octane
Loaded the test tune you posted. Loaded no problem. Failsafe Engine Mode still present. P2104 is gone P0600 is present. Here is a screen shot after programming and checked DTCs
Thank you
Thank you
p0600 isn't an ecu problem that means you have another module not working correctly. It should fire up and run albeit not happy since its not setup for any of the stuff on it.
fill out a vehicle info sheet for her and PM it to me and I'll hook you up
jcbryant
2.9 whipple
long tube headers
91 octane
where did the post go that had the bin file you sent to tune with pcm flash and mongoose?
its in your private thread on the premium member side
