2005 F250 BIN file assistance
jcbryant
Vehicle Information: 2015 5.0 from F150
2.9 whipple
132mm whipple throttle body
1050X injector dynamics
long tube headers
91 octane
2013 F150 3.5 ecoboost
2006 F350 6.0 Powerstroke
Unread post by jcbryant »
Hey all. The vehicle I'm learning on is a 2005 Ford F250 6.0 Powerstroke. I don't know exactly how to explain what I'm needing, though I'll try
I want to learn how to read the BIN file from a PCM then take it to a program like Tuner Pro.
I have HPtuners and SCT advantage to tune with but I'd like to learn more about how everything really works.
If that makes sense. I'd like to eventually read the FICM on the 6.0 Powerstroke as well.
I've downloaded TunerPro, I bought PCMflash and I downloaded EEC-IV-disassembler. Now that I type that I realized that the PCM from the F250 is probably not EEC IV. So it probably wont work. That's why I'm asking questions.
So far I've read the BIN file from the truck which I'm attaching.
I've tried opening the disassembler but I'm not having any success. I'm expecting a program window to open but I have a feeling I'm wrong and don't know where to start.
6U7AFFE_1FTSW21P06EC50168-20210703-222052 original.zip
(187.33 KiB) Downloaded 1189 times
Chris
Re: 2005 F250 BIN file assistance
you will need ida disassembler
decipha wrote: 2021 Jul 25, 14:46 you will need ida disassembler
or any disassembler, that already has the PPC processor and instruction set.
Ghidra is an alternative to IDA.
If using Ghidra, you'll probably need to tweak the language a little bit, add or modify instructions.
Seems to decompile somewhat using the MPC8270 or PowerQUICC-III variant.
Interesting, I've never seen "Copyright (C) Visteon Corporation 2000,2001,2002" before.
Either way, its a big undertaking, unless you have lots of time.
jcbryant
2.9 whipple
long tube headers
91 octane
Sorry haven't responded for some time. Been busy.
I think this is most likely more then I need to take on. Like wwhite said its a big undertaking and it takes lots of time.
I'd like to learn but I don't even have an understanding of writing code.
thank you wwhite and decipha for responding.
I just realized your a premium member.
If you still need something just LMK.
jcbryant
2.9 whipple
long tube headers
91 octane
Id like to continue learning but at this time I'm swamped with repair work and a couple small tuning fixes.
I did download IDA and a x32dbg and X64dbg
Here is the link to the 64 and 32 debugger I downloaded to try https://x64dbg.com/#start
This is the IDA disassembler I downloaded https://hex-rays.com/ida-pro/
Is this correct?
I try to drag and drop my BIN file into the debugger and it will not bring it up. they usually come up with an error.
I guess I probably need to learn some coding.
yeah coding is a must
I've heard there are some powerpc / motorola directives out there for ida.
Also, if your using IDA, you'll probably need to purchase it, as the 'Freeware' only supports x86/x64 code.
jcbryant
2.9 whipple
long tube headers
91 octane
I went to IDA licensing list. How do I know which to pick?
I would hold off on that first. Best bet is to take an eec-v binary and run it through the free disassembler and go through it and see if its even something your interested in before you go spending money on something you may never use.
Your a premium member so if you need something for the f250 just LMK no biggie.
