2006 Mustang & 1993 MarkVIII engine and transmission
Pguercio1
- Vehicle Information: 2006 Ford Mustang with
4.6l DOHC from 93 Mark VIII
Re: 2006 Mustang & 1993 MarkVIII engine and transmission
Ok
Thanks Michael for all you help
I guess I’ll have find analog gauges that will fit
In my cluster cutouts
Pguercio1
Hi Michael
I did all the harness work
Double checked it , installed it
And hooked up Battery
Everything seems to work
But I have a no start issue
The engine won’t turn over!
Could it be the Ford PATS system?
If so can I rip that out if the car?
there is no pats on 93 mark 8
are you saying the starter wont engage or the engine isnt firing ?
starter interrupt you can bypass by grounding that circuit at the original pcm connector or just run another relay trigger to the ignition switch
if the engine is cranking but not firing then you probably dont have power to the edis module.
Pguercio1
I hooked everything up,I tied into the wiring harness of the mustangs PCM for close proximity.
I took out the Mustangs PCM and benched it.
All that’s in the car is the Mark8 ECM and it’s harness.
I go to turn the key, I have acc power everywhere, but it won’t turn over.
The PATS system is in the Mustang from factory
I’m wondering if that could be the issue?
Pguercio1
Pguercio1
The Schematic is for an 06 Mustang
Pguercio1
Michael,
How do I bypass this starter interrupt at the original PCM Connector? Are you saying the Mustang connector?
Which wire should I ground?
You just posted it
pin 2 is the ground
pin 2 is the ground
Pguercio1
Ok thanks
I will ground pin 2 and try again,
I will let you know
I will let you know
Pguercio1
Hi Michael,
I grounded PIN number 2
And still nothing!!!
I have accessory power, I have lights, heater,
Windows, locks, power seats all working;
but when I turn the key to start position
‘nothing’ like a dead battery.
(It’s a new battery)
