2001.5 - 2004 Mustangs V6 GT Mach-1 Cobra Manual and Automatics
European spec strategy originally that SVT jacked for the 2004 updated cal for the cobras.
Decipha then jacked it and ported it over for everything. 4R70W controls work flawlessly.
TCC requires LUS and can be adjusted amongst shit ton of other auto values that are not populated.
MGZT is stock 2004 2V GT European calibration.
AMZ2 is latest updated 03/04 cobra cal.
ZYA2 fbgi0 conversion stock tune file for 03/04 mach-1 manual trans (originally RYAK1)
SYM2 fbgi0 conversion stock tune file for 03/04 mach-1 auto trans (originally FBFG2)
FBGI0 is known to conflict with the aice chip on some RVAFB and RVAF1 ecu's if not configured correctly. In those cases use CVAF1.
As of 2022 FBGI0 will replace RWAI2 for all 01-03 f150 trucks.
[FBGI0] Strategy Files
- DECIPHA_231116.adx
- FBGI0 selected
posted 23-nov-16 - (438.07 KiB) Downloaded 1344 times
- FBGI0_230504.xdf
- posted 23-05-23
- (1.98 MiB) Downloaded 1550 times
- MGZT_Stock.bin
- stock 04 manual 2v European GT
- (256 KiB) Downloaded 1517 times
- AMZ2_Stock.bin
- stock 03/04 cobra 4v sc latest update
- (256 KiB) Downloaded 1593 times
- fbgi0_boost_wb.cf4
- SCT Xcal Datalogging Configuration File
- (252 KiB) Downloaded 1601 times
Re: [FBGI0] Strategy Files
adx added
adx updated
ADX and XDF updated. Mismatched previously posted so logging was incomplete.
target iscdc completed today will be in next update
updated adx posted
target iscdc not going to be used til all the background isc idle modifiers are ran through
posted bone stock 03/04 mach-1 tunes fbgi0 converted
Posted updated FBGI0 xdf with several hundred parameters added most notably knock sensor and auto trans. Also fixed fn012 and fn016 as they were named backward. I also wrote patches for my fn2600 closed throttle decel spark code and fn880 dashpot dsdrpm follower code as well.
updated adx posted
not sure how long its been since I added the kam hego delay histogram but thats in there as well as vspd for actual vehicle speed not clipped so it goes up to 255 mph. 127.5 just isn't enough.
