Unknown Tune with HCI 302
Unread post by RinerAuto »
I recently purchased a complete engine and I got the tune with it. I'm still learning all the intricacies of tuning the ecu and going through the tuning documents on the homepage. I don't know anything about the person or company that created the tune. Would someone mind looking over the tune? I doubt there is anything that will cause issues, just looking for a second set of eyes.
I did a bin compare to a stock T4MO and there were quite a bit of changes.
ECU: T4MO
Tuning Hardware: Quarterhorse
Tuning Software TunerPro RT
Engine mods
Bottom end: stock 302
Heads: Trickflow 170cc 11r (SN 35274-07)
Intake: Holley Systemax
Trottle Body: BBK 75mm with Trickflow SN95 adapter
Cam: Anderson N41
Injectors: Bosch 30 lb/hr
Mass Air Meter: Pro-M 75mm 30lb cal
Fuel Pressure Regulator: Adjustable set to 40 psi
Timing Chain: Comp Cam double roller chain and sprocket
Valvetrain: Scorpion 1.6 roller rockers
Push Rods: Trickflow hardened
Valve Covers: Ford Racing tall covers
Headers: BBK shorty unequal
Thanks in advance
T4M0-Robert_4.bin
(56 KiB) Downloaded 628 times
Re: Unknown Tune with HCI 302
nothing stands out should run fine
Thanks. Waiting on a 4 to 6 pin MAF adapter, then I'll find out how she runs.
