95 W4H0 CBAZA V1 S-trim
Shdw1995
- Vehicle Information: 1995 Ford mustang GT/ 4:10 gears
Transmission- AODE w/ shift kit
Catch# W4H0
5.0/302
Stock Block/B31 Anderson Cam 544 Valve
Gt40 3 bar heads w/trick flow springs
Proform 1.6 Roller Rockers
Trickflow R series intake manifold
MSD Dis & Coil
Vortech V1 SC S-trim w/anderson power pipe
FR 42lbs injectors
ProM 80R SC-C maf
BBK Shortie headers
Off rode Xpipe
Flow master mufflers
Im looking to find a base tune to start with for a W4H0 any one?
Re: 95 W4H0 CBAZA V1 S-trim
Download the base tune T4M2, and follow the recommended changes. MAF data and injector data are necessary to set up your base tune. Every engine is different so it's best to start with a fresh tune with your. The injector data for most commonly used injectors is on the home page, same with mafs.
posted
