Will the c9c1 strategy work for a z2z truck ecu?(EFI-sd2x) It’s out of a 92 460 standard trans.
Also is there a data logging file available?
Z2Z Truck ECU
Dave67
- Vehicle Information: 2003 Ford Mustang GT, XSH1 Ecu, TVS 1900 supercharger, typical mods.
Re: Z2Z Truck ECU
I went to the homepage and typed in EFI-SD2 and yes its supported. Also yes I made an adx for it. I'll post if its not already there which im guessing its not.
http://efidynotuning.com/downloads.htm
Dave67
Re: Z2Z Truck ECU
Thanks! Ya, if the adx is there, I don’t see it.
Dave67
Re: Z2Z Truck ECU
Also, I tried to read the .bin from my Z2Z ecu (EFI-SSD21E) and it looks like garbage to me. Any suggestions? I have attached it. Thanks.
- z2z read.bin
- (56 KiB) Downloaded 1064 times
Re: Z2Z Truck ECU
its supposed to
you have to use the file provided
Dave67
Re: Z2Z Truck ECU
Oh ok.. Is it the D9S.bin I see in somebody else’s post? Or am I looking In the wrong place?
Re: Z2Z Truck ECU
its supposed to be wih the def file which i need to post it along with the adx soon as I get a chance
Re: Z2Z Truck ECU
Attached tune for 24lb injector on 460 engine manual trans. You'll have to dial it in but you should be able to get started.
ADX is in the strategy thread.
- Dave67_460startup.bin
- (56 KiB) Downloaded 1035 times
Dave67
Re: Z2Z Truck ECU
Thanks!
