Scaling Percentages?
Dave67
Vehicle Information: 2003 Ford Mustang GT, XSH1 Ecu, TVS 1900 supercharger, typical mods.
Unread post by Dave67 »
Ok, I plea dumb. What is this scaling percentages all about? I don't think that I need anything scaled. My current tune is from the S/C manufacturer. Id like to just dial in the fuel a little better. Thought id start by entering the actual deka 60 injector values and tune from there (the current tune has same number for high low slope and k constant). How do I enter the actual deka 60 injector values without messing up the rest of the tune? (I don't think I want the load or displacement or anything else that could mess with the spark advance to change). Or am I going about this wrong? I've only tuned eec IVs so far with BE. Always just used the injector settings for global fuel tuning and MAF Xfer for fine tuning.
Re: Scaling Percentages?
scaling percentage is if you have a fuel injector that clips the ecu input
see the 5th post down in this thread
viewtopic.php?t=192&f=5
Dave67
Ok. I kinda get that. My k constant and injector high slope are set to the same 53.641 in the current tune. If I apply the deka 60 patch it changes the k to 30. At this point what all would I need to copy and paste from the current tune to keep everything the same? Or should I not use the patch?
Dave67
Edited
