Transient fuel GUFX
Re: Transient fuel GUFX
obviously it is if your heating the fuel up that much
PaulC-turbo5.0
Single 67mm On3 BB turbo
tuning with Moates QH + TPRT
Well this probly explains it at least, it is something I’ve wondered about. I really don’t want to drop pump size again though.
Unread post by dleach1407 »
I moved my regulator to the rear of the car to combat fuel getting too hot. I used to have issues with boiling fuel.
PaulC-turbo5.0
well once again I need to thank you decipha!!! the swinging afr and hesitation issues I was having are completely gone! Did you do something beyond returning the 3 modifiers and kicking up fn1321? I feel like you had do something beyond that but havent found anything even with the compare tool.
also with the fuel pump and fuel heating up talk it made me take a closer look and realize that some of my fuel lines in the engine bay are pretty close to the turbo and hotside. I used some left over exhaust wrap and DEI cool tape to insulate/heat shield them. I feel like I am now seeing more consistency with my fuel error but need to drive it some more and take some longer trips to really see.
Nope you can see with the compare is tunerpro shows all differences.
yeah every bit you can do to keep the heat away will help but being in close proximity its still going to heat up.
What function does 1321 serve and is this something i should be looking at this function in CBAZA?
transient fuel
if u have transient fuel issues yes
is there a multiplier in CBAZA?
yep manifold volume
decipha wrote: ↑2021 May 24, 15:54 yeah don't be afraid to make big changes
Can you define big changes? 2x 4x 10x?
