4r70 possible TCC issue
mechanicalmatch
CVAF1
4R70 3.08
Engine dies coming to a stop, downshifts seem a bit more noticable. Fluid still nice and clean and not burnt. Gonna drop the trans pan this weekend and inspect. Would like to have TCC solenoid on hand when I go back together with it.
Any recommendations on quality solenoid brands?
00 F150 2wd 4.6 4r70
Cougar281
2002 PI 4.6L V8
1999 J-Modded 4R70W
2004 PTP2 PCM
Re: 4r70 possible TCC issue
Unread post by Cougar281 »
I would say Motorcraft. No other.
check the main bulkhead connector and make sure there's not trans fluid in there, if there is that means the seal is leaking and it could be shorting it out
make sure the filter didn't fall out and has a retainer
if its a custom tune on it make sure the 2-1 downshift tq modulation table is set to all 1s below 10 mph
mechanicalmatch
CVAF1
4R70 3.08
A little back story on the problem. It has been very cold recently. (Into the negatives) I start my truck and idle it every morning before I move it. I noticed a bit of a high pitched hum that seems to be pressure related to trans that only happens at cold ambient temps. If above 30 I don't notice it. Best way to describe something similar in sound is almost like an alternator hum thru speakers at times but not rpm dependent.
I will be dropping the pan tonight and will inspect and test harness and connections. I am also gonna pull connector from the eec and check there as well. I live in the rust belt now. No telling what I will find.
I do believe it to be either a short or an internal leak on the TCC solenoid.
I also have an aftermarket pan I have had for a while to go on it with a drain plug.
I will take a look at the calibration file. I haven't touched trans parameters in years on it.
Cougar281
2002 PI 4.6L V8
1999 J-Modded 4R70W
2004 PTP2 PCM
I never understand why people say 'if there's fluid in the connector, it's leaking and shorting out'. Transmission fluid is dielectric, and all of the electronic parts inside the pan are fully submerged in it. How will some seepage int he plug cause shorting, but not the components that are fully submerged in it?
no idea, i never understood it either until i experienced it myself
I've always chalked it up to one of them things beyond my knowledge.
mechanicalmatch
CVAF1
4R70 3.08
Dropped the trans pan. Nothing crazy in the pan. Not bad for 300k+ miles. TCC solenoid was intact. No cracks. Didn't find any issues. Replaced it anyway as I had a new one. Put it back together with a new trans pan, filter fluid.
Still doing the same thing. Took a look at the harness connector at trans bulkhead. Had some fluid. Cleaned it up best I could with brake clean. Checked eec connector. No issues.
Bumped the idle up a bit. No change.
I looked for the 2-1 torque modulation table and I don't see it. Im using the latest cvaf1 xdf.
Edit
Something else I noticed as well. Going into from park or neutral to reverse is fine, into drive is rough and may stall. If I keep it running in drive sitting still, foot on brake, and shift from drive to 2 it is easy on it but if I go to 1st it clunks. Going back to 2 is easy, into d is clunks. I say clunk but what I really mean harder than normal engagement.
I'm starting to thing this is cross talk hydraulically. Maybe a leak at the vb gasket? Maybe something beyond my knowledge of 4r70s? We shall see
mechanicalmatch
CVAF1
4R70 3.08
Finally got back around to this and figured it out. It became apparent when I could no longer back up a trailer that the problem is on the stator or torque converter. Pulled the trans. I found the torque converter ate into the stator support. It cut the front of the support, just behind the splines untill it broke.
The stock trans has 330k miles on it. I had a spare 4r70 with around 100k miles from a 2004 that I got a while back for $100, as I figured I would use it for hard parts. After a quick inspection, I put it in and it solved the problem.
I am going to rebuild the stock 4r70 and upgrade to a nice converter as a winter project and put it back in this spring and see if i get it right.
I got a flex plate that is drilled for both bolt pattern torque converter to keep my options open when I get another converter.
GrazW_Leeds68
Unread post by GrazW_Leeds68 »
mechanicalmatch wrote:I found the torque converter ate into the stator support. It cut the front of the support, just behind the splines untill it broke.
right mechanicalmatch, glad you finally cracked it, that stator support snapping is a proper nightmare to diagnose from the symptoms alone, i reckon most folks wouldve just kept throwing solenoids and seals at it like you did at first. im a bit surprised it took down to backing up a trailer before it showed its hand though, i'd have expected something that chewed up that bad to be alot more obvious earlier on, maybe even in the drive to 1 clunk you mentioned way back. decent shout grabbing that spare for £100 just to get rolling again, cheap insurance that. good luck with the rebuild over winter, get a proper quality converter in there this time and it should see you another 300k easy mate.
stokie_malc
Unread post by stokie_malc »
GrazW_Leeds68 wrote:that stator support snapping is a proper nightmare to diagnose from the symptoms alone
Not gonna lie, that stator support snapping is a proper swine to spot, GrazW_Leeds68, and I had a similar carry on with mine a few year back except mine gave itself away alot sooner. Had a 4r70 start whining under load, no clunking or owt dramatic, just a whine that got worse the hotter it ran, turned out the splines were already half chewed by the time I pulled it. Never got as far as mechanicalmatch's trailer test, mine seized up solid on the drive and that were that, tow truck and all. Definately makes you paranoid about every noise after though, i reckon i still check the trans temp gauge more than i should whenever it's cold out.
