Issue adapting tune for new heads and cam.
Re: Issue adapting tune for new heads and cam.
you might want to go with 875 for idle target. I think mine is up there in that range. It sounds fine like that to my ear. chop-chop cha chop
ColinA47
- Vehicle Information: 2005 Subaru WRX
Well, mine settled in nicely at 875 after I nudged it up off 800 lol.
AndreyK_bandsaw
- Vehicle Information: No EFI project car of my own at the moment. I work with metal-cutting band saws and machine-shop equipment, and I am here mainly to read and learn from the Speed Shop & Engine Talk section.
The collector leak is still worth fixing before you chase the last few degrees of idle spark. While the engine is held in open loop, closed-throttle fuelling is a bit of a moving target, and idle feedback spark has nothing stable to work against.
With this cam wanting more than the old 10 deg at idle, keep the dashpot spark below the new idle-spark target so the handoff is an increase rather than a drop. If the minimum/base has already been raised, the dashpot has to sit under that new number, not under the old 10 deg.
A slightly slower dashpot decay, and entering idle spark a little later, often stops the 1000-1100 hang and the stall that follows, even if you keep the 800 rpm target.
gaz_whitfield77
reckon doug's onto summat there with the torque reserve trick, had a similar carry on on my mates fox body years back, cam wanted more timing at idle or it just moans and dies on ya. 10 deg base is fine for a stock stick but these aggressive cams just dont like it, 18 sounds about right tbh. still wouldnt trust the dashpot drivability fully til that collector leak is sorted mind, chasing spark numbers while your stuck in open loop is like supporting sheffield united away from home, your never quite sure whats gonna happen 😂. get that leak welded up first then fine tune the decel side, saves you chasing ghosts.
x2, watford this saturday should be interesting being at Bramall it could go either way, 6 straight is asking alot
