Tunerpro RT Update - Oct 14, 2026
Post by decipha »
Few bug fixes mostly with table editing.
Anywho, new download available.
https://www.tunerpro.net/download/Setup ... _10335.exe
DougW
Vehicle Information: 1995 Ford Mustang GT 5.0
Cobra intake
70 mm throttle body
47lb. injectors
To do: AFR 165's and Voodoo cam
Re: Tunerpro RT Update - Oct 14, 2026
Post by DougW »
Cannot load CBAZA xdf file in version 6. Error is UT-8 encoding.
Any ideas?
Doug
Post by decipha »
use the v5 version for now, ill let mark know
Post by decipha »
Updated version posted that fixed it
https://www.tunerpro.net/download/Setup ... _0_422.exe
Also tunerpro.net had a facelift too
DougW
Cobra intake
70 mm throttle body
47lb. injectors
Post by DougW »
Thank you for the quick update. In three instances using the dashboard, there appears to be a memory leak. Program crashes randomly.
While on the dashboard subject, is there any way to operate as a separate window as before? I don’t see a maximize or minimize on the window border now.
Doug
Post by decipha »
damn well need more work then
can you go in to more detail with the program crashes and what your doing exactly?
DougW
Cobra intake
70 mm throttle body
47lb. injectors
Post by DougW »
I was editing a bin. Program was not connected to Quarterhorse or getting data. Opened up the dashboard to adjust the size and familiarize myself with the new version 6. Several times the program would simply crash to closed. No error messages received. I would have to start the program again. I think it happened once when connected to Quarterhorse and acquiring data.
Not sure if that helps, but it is all I’ve got.
Doug
