Trying to get a base tune to fire the car up. I followed the guide with the parameters I needed to change, just not sure why its not firing. I had it running okay on a stock tune with a calibrated maf.
I could have messed up the MAF scaling? Can anyone double check for me and give me some advice?
347 Stroker Base tune struggles
Slakkr183
- Vehicle Information: 1989 Mustang GT
A9S
347 stroker, 36 lb injectors, Comp XE274HR cam, Holley Systemax, accufab 75mm TB, 1 5/8 shorty headers, 1.6 rockers, EGR/Smog delete
- A9L2_347_Base.bin
- (56 KiB) Downloaded 22 times
Re: 347 Stroker Base tune struggles
there is no maf scaling you just plug in your actual maf curve
unfortunately no one can help you
before anyone can assist you they need to know your actual injector part number and your actual maf specs
Slakkr183
A9S
Injector is Ford F7PU-A4A. They are the dark blue body ones.
Should I go back to a stock MAF curve for now since I’m using a stock MAF?
For the MAF tables, I did the MAF multipler of 36/19 on the Y values.
Slakkr183
A9S
I’m likely headed your way soon for a tune. I’m just trying to get it running decent first.
if you have a stock maf then yes, put the stock maf curve in there
if you have a calibrated maf then put that calibrated curve in there
