Has anyone any experience using the Bluetooth module with quarterhorse?
It looks compatible according to the website, but not much info I could find.
Curious if it solves the serial COM bug issue where logging glitches out sometimes if you don’t set the data rates and frequency manually.
Moates Bluetooth module
danielt
- Vehicle Information: 1990 Ford Mustang 5.0LX Convertible
5-speed, stock drivetrain
danielt
Re: Moates Bluetooth module
I dont think its supported by tunerpro, at least I dont know of any bluetooth plugin, and it would take an adx specific for it to function correctly i would think
since ive never done it i highly doubt its been done on the qh with tp. When I see mark and craig this winter I'll bring it up and see if its even worthwhile.
As for the com bug glitch, Ive found when the qh works it just works, and when it doesnt it needs to be configured properly. Ive been pretty fortunate and never really get any glitches at least not often enough to be of any concern.
Follow the details in the getting started write up and you shouldnt have any issues.
one issue you will run in to is using cheap usb cables instead of the gold plated ones.
I have used the Bluetooth Module with BE. It works as serial port profile. TP should pick up the serial port as it does for usb.
oh nice, thats easy enough
danielt
Thanks to both! The only time it glitches is sometimes my laptop assigns some new random com port when it connects to the quarterhorse. Once I set the baud rate and sample frequency for the new port, it is fine.
