[AGANF] Strategy Files
96/97 Trucks 4.9/5.0/5.8/7.5 w/ Manual or E4OD transmissions
ML1-441 ECU Hardware Code
[AGANF] 1996-1997 Trucks 4.9/5.0/5.8/7.5 w/ Manual or E4OD transmissions. CFAK7 for 4R70W transmissions.
[CFAK7] 1996-1997 Trucks 4.9/5.0/5.8/7.5 w/ manual or 4R70W transmissions. AGANF for E4OD transmissions.
Attached AGANF xdf with bins.
No datalogging until TunerPro 2 bank logging is supported properly.
YDC0-B.bin
YDC0 - UPDATE TO ELT0 - 351 8 CYL AUTO
(256 KiB) Downloaded 152 times
ZIT0_GYA0_Combined.bin
ZIT0 - GYA0 CAL NON EMISSIONS
GYA0/DUO3 UPDATE TO ADA3 - 302 8 CYL AUTO 4X4, SAME CAL AS CAL3
(256 KiB) Downloaded 149 times
NNW2-B.bin
NNW2 - 6 CYL MANUAL - HIGH OUTPUT - 1 knock sensor
(256 KiB) Downloaded 144 times
KKD0-B.bin
KKDO/LOW3 UPDATE TO BAC3/NTD0 = 6 CYL AUTO
(256 KiB) Downloaded 153 times
SLUC_220310a8b4b_chopidle.bin
427 (351 stroker) GT40, cam, 30lb sc injectors @ 65psi base, 30lb cal MAF. 96 Bronco, 87 octane E4OD punisher vb, 4:88 axle 35" tire
(256 KiB) Downloaded 118 times
AGANF_240929.xdf
22-03-07
(48.65 KiB) Downloaded 148 times
