How to convert Breakpoint/MAF data to BE
lilxtra
Vehicle Information: 1987 Mustang LX,3.55's H pipe,K&N
Unread post by lilxtra »
Using BE to tune a W4HO strategy, had sworn off the '94-'95 cars for years but guy really wants me to do it, He is using the Ford LU47 injectors, I know the inj brkpoint from the references on this site can't be directly input into BE like the slopes can but don't remember the conversion/change that needs to be made, Also, does anything need to be changed on the min PW scalar?
What's the easiest way to convert the lbs/min data in the references page to KG/hr?
THANKS for any help on these simple, stupid questions!
Re: How to convert Breakpoint/MAF data to BE
Yes it can. Cbaza uses the 1991-2026 (current) standard breakpoint scalar equation.
Your confusing the older ones like the original fox ecu strategys (not my gufx though) which have a breakpoint function and requires converting.
minpw set to 0.000099 on all tunes regardless.
no need in converting simply copy and paste
you can use one of the base cbaza cals and tunerpro and then open that bin in BE if you wish. Be sure to disable datalogging in tunerpro before saving the file.
at some point, if its a boosted setup your going to need tunerpro to datalog to dial in fn1036
lilxtra
So I can just directly type the .00001307 into the scalar in BE,Correct? THANKS for the quick reply! He is using a PMAS MH30-HPX, I'm assuming the MAF file for HPX 3" will work? It IS supercharged (Procharger for 9# boost) so I guess I'm going to have to try to learn a new software program (TunerPro), I have TP RT and have looked at it but just got very confused as some of the parameters just look weird and not what I'm used to in BE and SCT programs, I have no idea how to datalog, view a log,etc. so it looks like I'm in for a good time:( LOL!! Thanks for all you do to help us!!
well your in luck, datalogging is far superior and significantly easier in tuneprro. You literally click a button, there's no setup or configuration involved.
read the getting started write up on the homepage
the more tools you have the better the tuner you'll become
lilxtra
When I try to copy/paste or type .00001307 into the Inj breakpoint scalar in BE it stays a.0000000 as it was when calibration/strategy was first opened? The maf transfer for the HPX 3" on the reference page should be good for what he has? THANKS again!
Any input, Decipha on this?
lilxtra
Any input on the post from June 21st?
I have no idea about BE.
correct
