Datalogging Patch will not apply
Turbo4V
Vehicle Information: 2000 Mustang
Twin Turbo 4V
PTP2 EEC-V
FBGI0
Unread post by Turbo4V »
Tried to re-enable the datalogging patch on a binary that was previously running on an F3 chip which had the datalogging patch removed. After updating the binary with the tune changes to use with the QH, I attempted to enable the patch but get the "Patch Aborted. Base Data Does Not Match". The binary loads fine onto the QH and runs but the logging is only partially functional as expected. Using the latest ADX and XDF from the downloads page, and latest TPRT build 5.00.10305.00 Not sure why this is happening.
TURBO4V_Working.bin
(256 KiB) Downloaded 2 times
Re: Datalogging Patch will not apply
remove the patch then add it
Turbo4V
Twin Turbo 4V
PTP2 EEC-V
FBGI0
The 'Disable Datalogging' patch is showing enabled, and the 'Remove Patch' button is grayed out. Is there another method to remove the patch?
I see. Attached with logging enabled. I'll remove the remove from the patch so its not a problem for others.
Thanks for that.
TURBO4V_Working.bin
Turbo4V
Twin Turbo 4V
PTP2 EEC-V
FBGI0
Thank you, appreciate the help.
