Going to use newest A9L2 but not certain on injectors
olddog
- Vehicle Information: Replica of 1967 AC Shelby 427 Cobra built 2001
Engine is 302 bored & stroked to 347
Mass Flow EFI set up. Designed to look like a 1960"s carb. Air filter on top of a 1000 cfm throttle body that resembles 4 barrel carb. MAF inside air cleaner. I have removed air filter & MAF. Put a "Hat" on and extended pipe. Put a PMAX HPX mass flow meter in the pipe. 36 lb/hr injectors. Fuel Return with regulator.
ECU-IV A9L
Edelbrock Performer heads
Edelbrock single plain Victor Jr intake with drilled and welded port injection
Comp cam 35-000-8 hydraulic roller
intake 0.550 lift duration @0.006 = 287 Opens 12 BTDC Close 44 ABDC
exhaust 0.576 lift duration @0.006 = 293 Opens 55 BBDC Close 7 ATDC
I believe I found the correct data on my injectors, but I am not certain it's correct. They came from Mass flow, with the entire kit. A9L eec iv, Edelbrock single plain intake with injector bunges welded in. Throttle body that looks like a carb, with Corvette Mass flow and a converter to voltage. MassFlow said they are 36 lb/hr injectors. The information I found says 42 lb/hr, but I believe that is rated at 45 psi fuel pressure, where Ford used 39 psi. I plan to use 45 psi fuel pressure.
I have changed out to a mass flow meter that, I think dicephia, recommend to me in 2014. I replaced the MassFlow air filter and mass meter with a fairly long pipe, to smooth out the reversion air flow from the cam.
Basically I started this in 2014 and it has sat unfinished since. My wife had health issues. Then my employer sold the business, and I was working and traveling all the time. Then I had to have a liver transplant followed by a kidney transplant. Now I am retired and back to good health. So I am just now getting back to finishing this. The biggest problem is that I have forgotten a lot.
Finally back to my question. Since I am not certain about my injectors and I have never ran the engine with the new mass flow sensor setup, I am thinking it would be best to put everything into an A9L bin. Run the engine and get the fuel sorted out. Then once I have it running decent at light to medium loads, put all that information into A9L2 and start turning. Does this sound like a reasonable place to start?
Re: Going to use newest A9L2 but not certain on injectors
no thats a horrible idea
a9l requires significant changes to dial in a bone stocker
is your injector data not on the homepage ?
what are the part numbers on your injectors ?
olddog
ECU-IV A9L
There is a number near the plastic part of the injector beside the electric plug. The Number is 01D114B. I searched and searched back in 2012. On Racetronic website I found item code 01D114X. It is a 37 lb/hr injector. The website data says 12.2 ohm. my injectors measure 12.0 to 12.1 cold. I believe it is my injector, but I'm not certain. Racetronix also listed the actual manufacturer as Standard Motor Products.
This is what I saved off of their website:
37 lb/hr Disc High-Z Fuel Injector
List Price: $35.00
Item Code: 01D114x
Weight: 90.00GM
Brands: Racetronix
Manufacturers: Standard Motor Products
Stock: Yes
Model INJL37
Categories: Fuel Injectors - High Impedance
Manufacturer P/N: FJ-SM-49S
Static Flow lb/hr (n-Heptane): 37
Static Flow Tolerance +/-%: 4%
Dynamic Flow (mg/pulse): 8.40
Dynamic Flow Tolerance +/-%: 4%
Coil Resistance Ohms: 12.2
Coil Resistance Tolerance +/- Ohms: .35
Spray Pattern: 3-Prong Cone
Connector Type: Minitimer (Bosch EV1
O-ring Type: Viton
E85 Compatible: Yes
Methanol Compatible: Yes
Description
01D114x ( INJL37)
TECHNICAL INFORMATION
Injector flow rates are based on testing with n-Heptane test solvent (0.6855 g/ml). U.S. EPA emission test gasoline 40CFR86.113 (0.735g/ml) flows in most common injector designs at about a 3 to 4% higher rate than n-Heptane. A ratio of 1.035:1 can be used when converting the flow specifications above.
This high-impedance injector will work with all factory ECM/PCM injector drivers.
ADDITIONAL INFORMATION
Top feed disc injectors uses multiple holes around its circumference. The disc rests on a short chimney that surrounds a metering hole. As the disc is raised off the chimney by magnetic force, fuel flows through the holes in the disc, over the walls of the chimney, and out the metering hole to form a full, finely atomized cone.
Performance advantages over pintle injectors (i.e. Ford / Bosch & Accel types) as listed by Delphi:
• The flat mating surface ensures that no excess fuel is present to evaporate and therefore, no deposits or clogging can occur.
• Compatible with alternative fuels (i.e. E85, Methanol)
• Longer service life
• High-speed disc action allows wider dynamic flow range for improved idling
• Quieter operation
• Revolutionary disc design resists build up deposits which can affect fuel flow.
• No Fuel leakage for quicker starts
• Grease supplied to lubricate o-rings prior to installation
List Price: $35.00
Item Code: 01D114x
Weight: 90.00GM
Brands: Racetronix
Stock: Yes
Model INJL37
O-ring Type: Viton
E85 Compatible: Yes
Description
01D114x ( INJL37)
• Quieter operation
olddog
ECU-IV A9L
I also found information that 01D114B is actually an accel 150140. This is the information that I saved on it.
ACCEL 150140 - 40# Hr Fuel Injector Specifications
Drive Circuit: "Saturated", R-C Voltage Suppression, 14.0 VDC
Coil Resistance: 12.2 ohms
Fuel Compatibility: Standard Gasolines and Ethanol Flex Fuels
Fuel Pressure: 300 kPa (43.5 psi)
Static Flow Rate: 280 gm/min n-Heptane – 38.34 lb/hr +/- 0.185 gasoline
Dynamic Flow Rate 8.40 mg/pulse at 2.5 ms, 10 ms period (100 Hz)
Approximated Time Offset: 0.70 ms
Approximated Slope: 4.67 mg/ms
Minimum Linear PW: 1.19 ms
Linear Flow Range (SAE): 20.6
Opening Time: 1.25 ms
Closing Time 0.68 ms
SMOV: 3.92 volts
Time offset:
Voltage Msec
6 4.009
8 1.878
10 1.260
11 1.103
12 0.950
13 0.818
14 0.729
15 0.598
SMOV: 3.92 volts
Time offset:
Voltage Msec
6 4.009
8 1.878
10 1.260
11 1.103
12 0.950
13 0.818
14 0.729
15 0.598
olddog
ECU-IV A9L
So I just used Copilot (an AI search engine). I put in the 01D114B fuel injector and it gave me stuff that didn't make sense. So I then explained the MassFlow system. It came back with (short version):
Siemens-Deka EV1 injector 36 lb/hr @ 39 psi
They flow 38lb/hr @ 43.5 psi
Copilot said for 43.5 psi and an A9L2 use this data:
FN367 High Slope 38.00
FN1360 Low Slope 43.20
FN389 Breakpoint (lb/inj) 0.000028
FN367A Injector Offset vs Battery Voltage
voltage row (V): 15.94, 15.00, 14.00, 13.00, 12.00, 11.00, 10.00
offset row (ms): 0.48, 0.52, 0.60, 0.72, 0.86, 1.05, 1.32
Bottom line: Copilot gives amazingly good information with great confidence. It equally gives absolutely wrong information with the same great confidence. It took me down the wrong road troubleshooting my Lincoln plug in hybrid. I spent over $300 on parts that were good. Then blew a fuse block that is located above the lithium battery that had to be removed. Dealership charged $2700 to fix it. Had I went to the dealer first, it would have been $900. So do I trust Copilot? Maybe. This looks reasonable. I ask you opinion. Trust this Data?
prolly good as any, seems to be in the ballpark compared to the others published data
olddog
ECU-IV A9L
Thanks!
I have downloaded the latest TunerPro, A9L2 bin, and the other two files. As I have said, I have forgotten most of this stuff, so I am sure I will have more questions.
olddog
ECU-IV A9L
The battery voltage offset is quite a bit different between the Accell and Siemens data. However I have always doubted that my injectors were made by Accel.
those values you posted are pretty reasonable compared to the other published data on the homepage for the other injectors in that line up.
comparing it to siemens is pretty useless as those are definitely not siemens injectors.
olddog
ECU-IV A9L
Injector offset:
The data I have listed 15.94 and 15.0. Then every volt down to 10.0. The A9L2 has the factory 19 lb injectors. It jumps from 14.0 to 15.94. It also has 0.91 in both the 14.0 and 15.94 rows. I assume they did this to prevent interpolating from continuing above 14 volts. Maybe to keep the offset constant in the normal operating range.
I left the 15.0 data point out and entered my 14.0 and 15.94 data points. I think this will leave the injector offset active all the time. Is this ok?
So the base A9L2 has voltages down to 5.5 set at 7.5 then 0 volt set to 7.5. Again I assume this is to prevent interpolation below 5.5 volts and clipping or freezing the offset at 7.5. My data only goes down to 10.0 volts. So I graphed my data, including the Y axes down to 5.5 volts, in Excel and charted it. Then added an exponential trend line. Then I added the x axes numbers, manipulating them until all data points were perftly on the trend line. I used the numbers to fill in my missing data. The voltage is no likely to go much below 10 anyway. I think I read something a long time ago that said the ECU will shut the engine off below 10 volts anyway. So is my generating the missing numbers ok?
