2006 expedition 5.4l e85
Now that e85 is half the price of regular unleaded in cali, my buddy wants to convert his expo. What hardware is needed for the diy tooner? Is it better to order a sct handheld with a canned e85 tune?
Re: 2006 expedition 5.4l e85
If he wants to get an xcal by all means go on and get one but without the pro racer package he wont be able to diy tune it.
if hes getting a can e85 tune then he wont be diy tuning?
the pro racer is fine if thats what he wants that would be his best bet co.pared to all other software options out there
What all does he have done to her ?
Its stock. I was thinking I could tune it for him just Not sure where to start on the newer stuff.
its all the same
set stoich to e85 and shoot mbt to it
put wot lambda at .83
set the fuel pressure to 65 psi over 0.000010 fuel flow, be sure to set the high load fuel pres delay timer to 0 !!!! thats required otherwise it will go lean at wot.
adjust the cold startup adding or removing fuel to find the sweet spot if need be.
then go to the etc table and copy the rows down. i.e. copy 4 to 3, 6 to 4 and copy the upper rows down. That way you dont have to get in to the throttle as hard so it stays in a higher gear with the converter locked and can still accelerate getting a touch better fuel economy with the new found power. Set the OL pedal threshold to about 60 for good measure.
Should pick up about 75rwhp on e85 (235rwhp stock to 310rwhp)
you may need to adjust the high slope deltap multiplier at 65psi if wot fuel is off. Henry sometimes extrapolates goofy values and just tosses them in if its a non normal running condition.
you can multiply the engine torque table by 1.15% at 80 load on up if you want, its not necessary but will firm up the trans at wot. You'll have to adjust the inverse table in that torque range too if you do.
you can also increase the torque modulation table values as well to reduce the torque reduction on up shifts if you want.
that "tune" is pretty basic if its stock, if u have any issues just lmk.
Awesome, thanks man. Is sctflash.com the best place to order the license and handheld?
i have no idea but sounds right
in all honesty if its all stock just get a mongoose and pcmflash
read the bin and shoot it to me i can edit it and shoot it back no big deal. Can give you a few tables to play with in tunerpro too no biggie.
Just saw this today thats awesome man. I guess Ive been dragging my feet for a reason. looks like the mongoose it pretty much the same cost as a sct handheld. Because we are in cali I will have to tune it back to stock every couple years. No big deal though right?
yep, no need to return to stock so long as its an EPA aopeoved tune which Id recommend.
but you cant compare them as they are entirely different
I finally got my PCMFlash dongle and VXDiag. Been testing everything out on my kids 98 explorer. Works perfectly. Here is a read from an 2005 E-350 5.4l 2V. I have started looking for the tables to build an XDF but do you have anything floating around that may make this go faster? This is all stock just changing it up for e85. The 06 Expo tune will be posted soon.
5C2ACYB_1FBNE31L25HA92369-20260725-093659.bin
(1 MiB) Downloaded 56 times
