Hey y'all, I'm working on attempting to tune my f250 and I have the bin file for my ecu (reman ecu about 1 year old, still have originals sticker which shows LAD1) but I can't seem to find any answer as to what xdf do I use for tuning the bin file? I'm a little new to this whole tuning thing so any pointers would be greatly appreciated. Thanks in advance!
Also, here's the bin I have found.
'96 F250 351w/e4od LAD1 xdf
Bucketshead20
- Vehicle Information: 1996 Ford F250XLT / LAD1 ECU / high rise carb intake with 75mm tb, full exhaust 3" with long tube headers.
- LAD1 (1).bin
- (56 KiB) Downloaded 496 times
Re: '96 F250 351w/e4od LAD1 xdf
looks at the hardware code, if its efi-sd4 then you can tune it with A1C
Bucketshead20
Thank you for that. one more quick question for you. My truck ran alright with my ecu untouched but I want to adjust different parameters and whatnot to dial it in. Seeing as my ecu is a sd4 LAD1 ecu can i just use the A1c Bin and a1c xdf on tunerpro rt and connect it to my quarterhorse with no issues? or do i have to adjust certain things first before i throw my ecu back in my truck and start it up?
