EEC IV questions
Re: EEC IV questions
there is no xdf for that strategy
Ah. Ok. Do you think A1C would be fairly close?
Thanks for this. At least it gets me close.034v wrote: ↑2025 Dec 03, 12:46 I have these as a possibility.
A0C2 5.8 Bronco, F-x50 E-x50 SD-Bank / E4OD Ban1 5.8 Bronco, F-x50 E-x50 SD-Bank / E4OD C2S2 5.8 Bronco, F-x50 E-x50 SD-Bank / E4OD C9S1 5.8 Bronco, F-x50 E-x50 SD-Bank / E4OD E0D 5.8 Bronco, F-x50 E-x50 SD-Bank / E4OD JAG2 5.8 Bronco, F-x50 E-x50 SD-Bank / E4OD S0M 5.8 Bronco, F-x50 E-x50 SD-Bank / E4OD X2Z2 5.8 Bronco, F-x50 E-x50 SD-Bank / E4OD C3P1 5.8 1993-95 Lightning SD-Bank / E4OD / F3TF-12A650-AB C3P2 5.8 1993-95 Lightning SD-Bank / E4OD / F3TF-12A650-AC C3P3 5.8 1993-95 Lightning SD-Bank / E4OD / F3TF-12A650-AD ICY1 5.8 1993-95 Lightning SD-Bank / E4OD / F5TF-12A650-XB
yeah you should be able to run an a1c tune on there no prob
<edit- corrected>jsa wrote: ↑2025 Dec 03, 01:32 DCLHP looks to be enabled in the bin and the external interrupt also, but for whatever reason I can't get your bin too talk on the DCL capable hardware I have here. So none the wiser on catch code.If your hardware code is the same as A1C then you can run A1C on your hardware. A1C will need to support the same functionality as your bin does, so it may/not work out depending on similarity/difference.Code: Select all
SYM 52 "DCLHP" :B1 # DCL Hardware Present SYM B003 "S.LINK_SW_UART&DOL&DCL"
We agree LINK_SW is 0xB003 and equals 0x6 or bin 0000 0110.
I disagree.
Bit 0 = 0
Bit 1 = 1 DCL hardware is present.
Bit 2 = 1
Bits 3 to 7 = 0
Bit numbering starts at zero.
AH, sorry, dam, was late in the day, no excuse.
Yup, your correct, not sure what I was thinking.
