Startup enrichment trouble from heat soak
Re: Startup enrichment trouble from heat soak
Maybe get it hot and smoke test for an oddball leak in the piping or intake?
that's two different temps 204 vs 184
both look to be lean and need more fuel as the engine doesn't seem to settle
Single 67mm On3 BB turbo
tuning with Moates QH + TPRT
Can you try to elaborate more on why you say that? I know the second one is lean that’s the problem I’m just trying to fix. But I’m not sure what you’re seeing in the log of the first that I’m not picking up on in the log or in person?
with more fuel the idle should be more stable, the engine doesn't look like its happy as the rpm's are jumping around
regardless you can command any enrichment you want for 184 vs 204 degrees as the two are completely different. You can see a few seconds after fire off the ect's plummet on the one log.
