85 Mustang 4-Eye GT Hatchback Speed Density Tuning
Denver_SVT
- Vehicle Information: 2001 Mustang Roush Stage 3 Supercharged with Build Engine
I have just bought my first Fox-Body a week ago and i am very exited to tune it the first time through Speed Density setup.
Modifications Parts:
* New refreshed 87 Mustang 5.0 engine swap, T5 Transmission with speed density using the EEC-IV SFI-SD1 ( E7SF-12A650-C1A) "DC".
*98 Cobra Differential with Axels and 5 Lug conversion and Cobra 2-pistons brake system. Stock Gear ratio.
* BBK Cold Air Intake to the fender.
* BBK LT Headers with custom 2.5 X-Pipe and Flowmaster mufflers.
* E-303 Cams
* MSD 6AL part number (6420) with Performance TFI Coil and Ford Racing Spark red cables.
* Stock Intake Manifold, Stock Throttle Body, Stock 19 lb Injectors.
* Planning soon to install the Trick Flow manifold or the lower edelbrock intake manifold with edelbrock Big elbow and 90 mm TB. Which one you will recommend?
I tried to open the strategy code (DC) through my SCT Advantage software but i couldn't. So, My option either to go with following:
*Binary Editor
*Quarter horse
*Tuner Pro
*SCT Eleminator Chip but the issue i cannot find the DC strategy code and i will be limited with tuning. correct me if i am wrong.
*Stand alone system not my option for this moment.
I am looking for a reliable tuning software with datalog that will allow me to tune the vehicle perfect even when i plan to stroke it and have power adder in the near future.
The vehicle right now super rich and i can smell the gas with burning my eyes at Idle and cruise lol.
what do you recommend me to choose and start dialing my tune using a Def. file with the same of my setup?
Do you think going with MAF conversion and A9P or A9L ECU is a good idea or waste of money ?
Thanks for your advice.
* E-303 Cams
*Binary Editor
*Quarter horse
*Tuner Pro
Re: 85 Mustang 4-Eye GT Hatchback Speed Density Tuning
Best bet is to upgrade to the 94/95 gt automatic ecu with the quarterhorse and tunerpro.
Denver_SVT
Sounds good. Do you have the strategy codes of the 94/95 GT ECU to look around for them? Can you explain why the best bet is to go with automatic ECU? Why not manual? Just for my knowledge i would like to know the reason.
http://efidynotuning.com/cbazaswap.htm
auto ecu is cheaper easier to find and has more hardware so u can run a 4r70w later down the line too
Denver_SVT
Hi Decipha, i found this ecu (FCL0) from 95 Mustang 5.0 Auto i guess.
Is this ecu have any relation with CBAZA strategy?
Denver_SVT
Ok good. When i replaced the ECU do i need Ford dealer to reprogram the ecu with my VIN # like the new edge and new stangs? or is there away to configure it.
no we reprogram vins and pats ourselves here
nope no vin or theft on those older ecus
Denver_SVT
Excellent. Thanks for the support. Once i have the ecu i will PM you to work it out of getting the Quarterhorse and TunerPro
everything you need to know is in the getting started write up on the homepage
