MNAE0 support
00/01 SVT Lightning
m-barans
MNAE0 support
Unread post by m-barans »
I am just wondering what the status is on support for this OS. Has a custom strategy with definition file and data-logging been developed?
I’m curious as I want to start working with my truck which is stockish currently…
Re: MNAE0 support
mostly
would take a premium membership to make time to complete it
when u plan on tinkering?
m-barans
Re: MNAE0 support
Not immediately, likely summer
I’m perfectly fine with supporting as a premium member also
