Flex Fuel Control
Re: Flex Fuel Control
It can take a 5-10 minute drive and several adjustments to get it settled back down. I have a 38 Gallon rear tank and 17 or so up front so depending on their level it can also be hard to get them balanced when refueling. The point of all of this is to not have to think about it or mess with tuning when switching fuels or tanks.
I will optimize the code as you mentioned once I have settled on the final code. I hate having to recalculate jumps constantly so I will take your advice later on in the development process. All of the input is greatly appreciated.
Assuming LAMAVE is scaled the same as LAMBSE1:
Example if LAMAVE is 10% lean or .900 (0x7400)
If 0x7400 < 0x8000
R34 = (0x8000-0x7400) + KAMAFR 'input to UROLAV Function
If KAMAFR was previously 8be5 (14.64:1) the new value would be 97e5 (13.48:1)
0x8000 - 0x7400 = C00
C00 + 8eb5 = 97e5 (38885)
524288/38885 = 13.48
Obviously will need to be flipped if LAMAVE is greater than 0x8000. Any thoughts before testing this?
If 0x7400 < 0x8000
lambse is a byte
0x80 (128) == 1.0 lambda
why even consider a word?
sailorbob
LAMAVE is scaled the same as LAMBSE.
90% of 0x8000 is 0x7333 so your example values need a little adjusting.
LAMBSE is clipped to a maximum of 0x8000 to prevent lean excursions so I would expect LAMAVE to not exceed 0x8000 too.
If I run some gasoline without adjusting StoichAFR, lambse during CL will stay above 1.0 while it is pulling fuel. I am assuming 1.1 Lambse will be around 8c (or 8c00 when applying to AFR Word) in which case I believe this code will work to prove the concept. More code is still needed for validation and to avoid making unnecessary updates to KAMAFR. I should be able to test this later on today.
Sub_a30d:
a30d: ef,2e,b1 call 543e Sub_543e ();
a310: 32,9f,01 jnb B2,R9f,a314 if (B2_R9f = 1) {
a313: f0 ret return; }
a314: a1,00,80,34 ldw R34,8000 R34 = 8000;
a318: 88,96,34 cmpw R34,R96
a31b: d1,0c jleu a329 if (R34 > R96) {
a31d: a3,ee,96,32 ldw R32,[Ree+96] R32 = [716];
a321: 68,96,34 sb2w R34,R96 R34 -= R96;
a324: 64,32,34 ad2w R34,R32 R34 += R32;
a327: 20,10 sjmp a339 goto a339; }
a329: a0,96,32 ldw R32,R96 R32 = R96;
a32c: 69,00,80,32 sb2w R32,8000 R32 -= 8000;
a330: 47,ee,96,32,34 ad3w R34,R32,[Ree+96] R34 = R32 + [716];
a335: a3,ee,96,32 ldw R32,[Ree+96] R32 = [716];
a339: a3,f8,18,36 ldw R36,[Rf8+18] R36 = [adf0];
a33d: ef,32,a4 call 4772 Sub_4772 ();
a340: c3,ee,96,3e stw R3e,[Ree+96] [716] = R3e;
a344: f0 ret return;
Test worked but kept chasing the 02 switching. Here is an update to resolve. Going to spend some time with the fam now.
Sub_a30d:
a310: 3a,9f,0c jb B2,R9f,a31f if (B2_R9f = 0) {
a313: 89,00,77,96 cmpw R96,7700
a317: d1,07 jleu a320 if (R96 <= 7700) goto a320;
a319: 89,00,83,96 cmpw R96,8300
a31d: db,11 jc a330 if (R96 >= 8300) goto a330; }
a31f: f0 ret return; }
a320: a1,00,80,34 ldw R34,8000 R34 = 8000;
a324: a3,ee,96,32 ldw R32,[Ree+96] R32 = [716];
a328: 68,96,34 sb2w R34,R96 R34 -= R96;
a32b: 64,32,34 ad2w R34,R32 R34 += R32;
a32e: 20,10 sjmp a340 goto a340; }
a330: a0,96,32 ldw R32,R96 R32 = R96;
a333: 69,00,80,32 sb2w R32,8000 R32 -= 8000;
a337: 47,ee,96,32,34 ad3w R34,R32,[Ree+96] R34 = R32 + [716];
a33c: a3,ee,96,32 ldw R32,[Ree+96] R32 = [716];
a340: a3,f8,18,36 ldw R36,[Rf8+18] R36 = [adf0];
a344: ef,2b,a4 call 4772 Sub_4772 ();
a347: c3,ee,96,3e stw R3e,[Ree+96] [716] = R3e;
a34b: f0 ret return;
sailorbob
That's why I thought LAMAVE might be a better value to use.
Implemented LAMAVE and the code is working. Thinking of just creating a counter that only updates KAMAFR every 500 passes or so. A timer is probably more CPU efficient, but I am not sure how to implement. Not a lot about timers in the docs.
LAMAVE = [3ca]
LAMAVE = [3ca]
Sub_a30d:
a310: 3a,9f,10 jb B2,R9f,a323 if (B2_R9f = 0) {
a313: a3,e8,4a,32 ldw R32,[Re8+4a] R32 = [3ca];
a317: 89,00,77,32 cmpw R32,7700
a31b: d1,07 jleu a324 if (R32 <= 7700) goto a324;
a31d: 89,00,83,32 cmpw R32,8300
a321: d9,12 jgtu a335 if (R32 > 8300) goto a335; }
a323: f0 ret return; }
a324: a1,00,80,34 ldw R34,8000 R34 = 8000;
a328: a3,ee,96,32 ldw R32,[Ree+96] R32 = [716];
a32c: 6b,e8,4a,34 sb2w R34,[Re8+4a] R34 -= [3ca];
a330: 64,32,34 ad2w R34,R32 R34 += R32;
a333: 20,0d sjmp a342 goto a342; }
a335: 69,00,80,32 sb2w R32,8000 R32 -= 8000;
a339: 47,ee,96,32,34 ad3w R34,R32,[Ree+96] R34 = R32 + [716];
a33e: a3,ee,96,32 ldw R32,[Ree+96] R32 = [716];
a342: a3,f8,18,36 ldw R36,[Rf8+18] R36 = [adf0];
a346: ef,29,a4 call 4772 Sub_4772 ();
a349: c3,ee,96,3e stw R3e,[Ree+96] [716] = R3e;
a34d: f0 ret return;-
After several bugs and iterations, this code worked out beautifully. Still under development but I am posting the XDF and ADX in case anyone is interested. The ADX includes payloads for KAMAFR and KAMLAMAVE(my implmentation of rolling average of lambse1)
Any recommendation on minimum temp for KAMAFR updates? I want it to occur before the main adaptive routine runs as to not mess up those trims. I am thinking like 160-170 deg f.
Sub_a30d:
a310: 3a,9f,31 jb B2,R9f,a344 if (B2_R9f = 0) {
a313: a0,96,32 ldw R32,R96 R32 = R96;
a316: a3,ee,9a,34 ldw R34,[Ree+9a] R34 = [71a];
a31a: a3,f8,18,36 ldw R36,[Rf8+18] R36 = [adf0];
a31e: ef,4f,a4 call 4770 Sub_4770 ();
a321: c3,ee,9a,3e stw R3e,[Ree+9a] [71a] = R3e;
a325: a3,ee,9c,32 ldw R32,[Ree+9c] R32 = [71c];
a329: 07,32 incw R32 R32++;
a32b: c3,ee,9c,32 stw R32,[Ree+9c] [71c] = R32;
a32f: 89,80,00,32 cmpw R32,80
a333: d1,1d jleu a352 if (R32 <= 80) return;
a335: 89,00,7d,3e cmpw R3e,7d00
a339: d1,18 jleu a353 if (R3e <= 7d00) goto a353;
a33b: a1,00,81,34 ldw R34,8100 R34 = 8100;
a33f: 88,3e,34 cmpw R34,R3e
a342: d1,19 jleu a35d if (R34 <= R3e) goto a35d; }
a344: 01,32 clrw R32 R32 = 0;
a346: c3,ee,9c,32 stw R32,[Ree+9c] [71c] = R32;
a34a: a1,00,80,34 ldw R34,8000 R34 = 8000;
a34e: c3,ee,9a,34 stw R34,[Ree+9a] [71a] = R34; }
a352: f0 ret return; }
a353: a3,ee,96,32 ldw R32,[Ree+96] R32 = [716];
a357: 65,ff,00,32 ad2w R32,ff R32 += ff;
a35b: 20,08 sjmp a365 goto a365; }
a35d: a3,ee,96,32 ldw R32,[Ree+96] R32 = [716];
a361: 69,ff,00,32 sb2w R32,ff R32 -= ff;
a365: c3,ee,96,32 stw R32,[Ree+96] [716] = R32;
a369: 01,32 clrw R32 R32 = 0;
a36b: c3,ee,9c,32 stw R32,[Ree+9c] [71c] = R32;
a36f: f0 ret return;- Attachments
- A1C_240502_FlexFuel.xdf
- (425.56 KiB) Downloaded 385 times
- DECIPHA_FlexFuelA1C.adx
- (444.88 KiB) Downloaded 399 times
haven't tested this yet but includes ECT,RPM and TP ranges. Also increased update frequency.
Sub_a30d:
a310: 99,55,b6 cmpb Rb6,55
a313: de,46 jlt a35b if (Rb6 >= 55) {
a315: 89,00,20,b2 cmpw Rb2,2000
a319: de,40 jlt a35b if (Rb2 >= 2000) {
a31b: 89,70,17,b4 cmpw Rb4,1770
a31f: de,3a jlt a35b if (Rb4 >= 1770) {
a321: 89,10,27,b4 cmpw Rb4,2710
a325: d6,34 jge a35b if (Rb4 < 2710) {
a327: 3a,9f,31 jb B2,R9f,a35b if (B2_R9f = 0) {
a32a: a0,96,32 ldw R32,R96 R32 = R96;
a32d: a3,ee,9a,34 ldw R34,[Ree+9a] R34 = [71a];
a331: a3,f8,18,36 ldw R36,[Rf8+18] R36 = [adf0];
a335: ef,38,a4 call 4770 Sub_4770 ();
a338: c3,ee,9a,3e stw R3e,[Ree+9a] [71a] = R3e;
a33c: a3,ee,9c,32 ldw R32,[Ree+9c] R32 = [71c];
a340: 07,32 incw R32 R32++;
a342: c3,ee,9c,32 stw R32,[Ree+9c] [71c] = R32;
a346: 89,40,00,32 cmpw R32,40
a34a: d1,1d jleu a369 if (R32 <= 40) return;
a34c: 89,00,7d,3e cmpw R3e,7d00
a350: d1,18 jleu a36a if (R3e <= 7d00) goto a36a;
a352: a1,00,81,34 ldw R34,8100 R34 = 8100;
a356: 88,3e,34 cmpw R34,R3e
a359: d1,19 jleu a374 if (R34 <= R3e) goto a374; } } } } }
a35b: 01,32 clrw R32 R32 = 0;
a35d: c3,ee,9c,32 stw R32,[Ree+9c] [71c] = R32;
a361: a1,00,80,34 ldw R34,8000 R34 = 8000;
a365: c3,ee,9a,34 stw R34,[Ree+9a] [71a] = R34; }
a369: f0 ret return; }
a36a: a3,ee,96,32 ldw R32,[Ree+96] R32 = [716];
a36e: 65,ff,00,32 ad2w R32,ff R32 += ff;
a372: 20,08 sjmp a37c goto a37c; }
a374: a3,ee,96,32 ldw R32,[Ree+96] R32 = [716];
a378: 69,ff,00,32 sb2w R32,ff R32 -= ff;
a37c: c3,ee,96,32 stw R32,[Ree+96] [716] = R32;
a380: 01,32 clrw R32 R32 = 0;
a382: c3,ee,9c,32 stw R32,[Ree+9c] [71c] = R32;
a386: f0 ret return;
