1993 ranger 4.0 XDF
Re: 1993 ranger 4.0 XDF
working on some timing stuff. The load scaling is strange to me. Is this a MAF setup? I may be looking at the wrong load function.
RAT1_250114.xdf
(16.85 KiB) Downloaded 683 times
yeah I believe C268 (a268) is the correct function. I will update soon. what is a usual load range for MAF?
I think I should be using a different strat as a template instead of A1C. Anyone know what the closest XDF available would be for this vehicle? It is distributorless with a cam synchronizer if IRC
yeah this looks better:
tufgriz
Vehicle Information: 1993 4.0 Ranger xl Currently stock RAT1
1989 mustang gt running Megasquirt HCI 302 swapped back to a9l
Unread post by tufgriz »
yes it is maf
tufgriz
efloth wrote: ↑2025 Jan 21, 15:29 I think I should be using a different strat as a template instead of A1C. Anyone know what the closest XDF available would be for this vehicle? It is distributorless with a cam synchronizer if IRC
no cam sync on this one, its a federal emissions. California version had the cam sync and sequential injection
tufgriz
efloth wrote: ↑2025 Jan 21, 15:48 yeah this looks better:
Much appreciated good sir!
RAT1 is MA46G hardware, that is mass air, not SD.
The interesting thing about MA46G hardware, is that it is the same circuit board as the SD4x board.
It has DOL on it, for fuel data on dash gauge.
tufgriz
wwhite wrote: ↑2025 Jan 21, 19:04 RAT1 is MA46G hardware, that is mass air, not SD.
most likely leftover from explorers possibly? as I know they had more of that style features being a luxury type rig in the day but based of the ranger chassis
Best to use RZASA for all templates as it has everything populated.
