EEC V file conversion
Re: EEC V file conversion
If it isn't a quick easy simple fix then do not worry about it, just figured I would ask about it. May not bother most everyone else. Like I said I am so very new to all of this. I can go back and forth as needed. I am not trying to create any unnecessary work for you. Thanks
Reading the STB - Store Byte opcode description, there is absolutely zero mention of 'WORD'.jsa wrote: ↑2024 Dec 13, 14:45 C6 is Indirect address mode.Software_Manual wrote:
R28 holds a word length address, so bytes 1 & 3 are combined as the word length address destination, with a store size of one byte, for the byte length data held in source R2B.
Byte1/R29 is the address word high byte.
Byte3/R28 is the address word low byte.
You are describing STWSTB can transfer an 8-bit "B" operand to any 8-bit "A" operand location in memory
STW can transfer a 16-bit "B" operand to any 16-bit "A" operand location in memory
tvrfan
That's true. I think that is true for all opcode descriptions actually. In the 'address modes' section of manuals, in a different place from opcode descriptions, it does say that all addresses (indirect and indexed) are treated as 16 bit words. I still reckon I haven't found anywhere where it says that byte offsets in indexed mode are signed, but we know they are from the bins.
There are still a few odd details about the CPUs which I reckon are still technically 'unknown' even with the official Ford manual. Quite a lot of the 'special chips' (DUCE) etc are also not well documented and down to guesswork.
tvrfan
I remember that problem and thought I had fixed it. Damn.BOOSTEDEVERYTHING wrote: ↑2024 Dec 14, 10:04 It just will not print the labels on arg lines. I used the same DIR, CMT, and BIN files for both versions and here is the same section of code from each.
<snip>
Thinking about where v4 is up to it's probably about time to release 4.12 as stable anyway.
It seems to get used a lot (from comments here).
Yes, been too focussed on trying to get V5 to work right. It uses a different method to analyse/disassemble the bin file.
So I shall reload 4.12 source and try to reproduce/fix the problem, so it will become 4.13.1, and I will also do a tidy up in Github.
tvrfan
the way I see it is that
STW and STB are the only opcodes which can store/write a value outside the CPU registers, so they are, in effect, a 'reverse' LDX and LDB.
(oops, PUSH, PUSHP also write outside the CPU too)
Indeed, the expectation being that address modes are well understood.
For STB I said;
For STW I'd say;
R28 holds a word length address, so bytes 1 & 3 are combined as the word length address destination, with a store size of one word, for the word length data held in source R2A as an example.
Software_manual wrote: 3-2.3.5 INDIRECT ADDRESS MODE
location between addresses ^0000 to '^FFFF using a 16-bit effective address(EA). The 16-bit effective address is
stored as a WORD variable
tvrfan
Boosted - can you send me your comment lines from 07f19 to 07f2e ?? thanks.BOOSTEDEVERYTHING wrote: ↑2024 Dec 14, 10:04 It just will not print the labels on arg lines. I used the same DIR, CMT, and BIN files for both versions and here is the same section of code from each.
V4.012<snip>Code: Select all
Sbg07F12_RZAxxxxx_21.1.18.10_AIR_SELF_TEST_EO: 07f12: a0,79,26 ldw R26,R178 TEMP1L = IMAF; 07f15: 8b,fe,0a,26 cmpw R26,[Rfe+a] 07f19: d1,13 jleu 07f2e if (TEMP1L <= MAF_HI_KOEO) goto 07f2e; } # JGTU from L07F07 Sbg07EF0_RZA9BC2F_21.1.18.5_AIR_SELF_TEST_ER_ENTRY # SJump from L07F0F Sbg07EF0_RZA9BC2F_21.1.18.5_AIR_SELF_TEST_ER_ENTRY 07f1b: b3,d8,2d,c6 ldb Rc6,[Rd8+2d] FLAGTEMP_BG = AIR_BACK_FLAGS; 07f1f: 3b,c6,0c jb B3,Rc6,07f2e if (B3_FLAGTEMP_BG = 0) { 07f22: b3,d8,2d,c6 ldb Rc6,[Rd8+2d] FLAGTEMP_BG = AIR_BACK_FLAGS; 07f26: 3a,c6,05 jb B2,Rc6,07f2e if (B2_FLAGTEMP_BG = 0) { 07f29: ef,2e,59 call 0d85a Sxx0D85A_ALSO_RZA0F887_39.1.1.2.8_STORE_CODE(&Pxxx) ( 07f2c: 9e,0a #arg 1 a9e ); } } } } } } # JLEU from L07EF5 Sbg07EF0_RZA9BC2F_21.1.18.5_AIR_SELF_TEST_ER_ENTRY # JLEU from L07EFE Sbg07EF0_RZA9BC2F_21.1.18.5_AIR_SELF_TEST_ER_ENTRY # JC from L07F0D Sbg07EF0_RZA9BC2F_21.1.18.5_AIR_SELF_TEST_ER_ENTRY # JLEU from L07F19 Sbg07F11_RZA9BC52_12.1.18.6_AIR_SELF_TEST_EO_ENTRY # JB from L07F1F B3_FLAGTEMP_BG = 1 Sbg07F11_RZA9BC52_12.1.18.6_AIR_SELF_TEST_EO_ENTRY # JB from L07F26 B2_FLAGTEMP_BG = 1 Sbg07F11_RZA9BC52_12.1.18.6_AIR_SELF_TEST_EO_ENTRY 07f2e: 20,63 sjmp 07f93 goto 07f93;
I don't remember the wrong sym name being printed...
Thanks.
tvrfan
Everyone,
Dug up some of my old emails for reported V4 issues, and thanks to jsa for sending me some more.
So will start a 'v4 bugfix' run from now.
here are the lines requested from my CMT file.. Also, the DIR and CMT files are in a file a posted a page or so back. The BIN file I have been using is also in the zip file, I believe.
07F10 \n\n # SCall from L07E0B \t83\s07DF0
07F1A \n\n # JGTU from L07F07 \t83\s07EF0
07F1A \n # SJump from L07F0F \t83\s07EF0
07F2D \n\n # JLEU from L07EF5 \t83\s07EF0
07F2D \n # JLEU from L07EFE \t83\s07EF0
07F2D \n # JC from L07F0D \t83\s07EF0
07F2D \n # JLEU from L07F19 \t83\s07F11
07F2D \n # JB from L07F1F \sC6:3 = 1 \t83\s07F11
07F2D \n # JB from L07F26 \sC6:2 = 1 \t83\s07F11
07F2F \n\n # SCall from L07E16 \t83\s07DF0-
Just in case, here are the updated cmt, dir, and bin files.
- CRAI8_20241216.zip
- (504.72 KiB) Downloaded 450 times
