Individual cylinder timing
VJordan
- Vehicle Information: 2001 mustang 4.6 2v turbo cvaf1
Is it possible to do individual cylinder timing on cvaf1 ? At least for cylinders 7&8 on a 4.6 . If so what scalar would it be?
Re: Individual cylinder timing
SPKAD_CYL9 is cylinder 8 and SPKAD_CYL8 is cylinder 7.
VJordan
I checked those and somehow cyl9 was -3 and cyl8 was -0.25
So I made cyl8 -3 also and it just backfires like crazy out the exhaust if I put it back to -0.25 it’s fine
sounds like your using the wrong bin file
VJordan
It’s the same bin I’ve been running for the past year or so ,
I tried the newest one you posted but the car wouldn’t stay running and I didn’t have the time to find why so I switched back to the bin it’s been on
You learn nothing if you don't figure out why something doesn't work when it should.
VJordan
I’m going to try it again and see why it wouldn’t run I just didn’t have the time at that moment that’s why I switched back
Is it possible for the fuel pump to be getting maxed even the duty cycle says .43 which is about 86 percent ? I can’t get the fuel pressure to follow 40 I’ve played with the pids , I halved them at first but I don’t really know what to do with them just been trying different settings . When rolling into the throttle fuel pressure shoots up then drops to about mid 20s the afr stays fine though because of the compensation so I haven’t worried about it too much but would rather not have the pressure so low
the fuel pressure histogram shows you exactly what it needs to be
just simply take the corrections tunerpro gives you and apply them
fuel pres sure be solid as a rock then
