Ok, I did try to do this in several places but it wasn't working for me. Maybe that is why. It was throwing off the naming in other subroutines as well, so I was having to define it at every address and that was a pain. I'll try it with the default name at the bottom and see if that works for me.I find it best to put the default name at the bottom of the range set.
Not at all. I can use all of the help I can get. LOL. I have issues seeing the index of things, I guess. I know there has to be a way for it to say I add this amount to this base address for cyl number #. I just do not see it anywhere in this code. Maybe once I find it, I will understand it better.Note - If that sounds condescending, sorry, just trying to help that you need to be able to 'get' how low level code works for this kind of stuff.
I noticed there are 2 tables for each of the following and one set is shorter than the other, are these just not named properly, or is this correct?
uyTb2x1327A
uyTb1327A
uyTb1329
"uyTb1329A"I have not found references to 2 of each of these in the strategy docs, but have come to realize the strategy docs are not always correct.
