only the marauder ecu's have a tach out AFAIK, none of the none marauders except maybe? the crown vic sports have a tach output wire.
The hardware is physically missing in the other ecus.
May be better off using a cluster from an 02-04 mustang and just using the FBGI0 strategy so the tach is sent over scp.
98 explorer pcm tuning help newbie
Re: 98 explorer pcm tuning help newbie
Did you get yours working?
98 stang is scp as well so it doesnt need a tach out but id imagine some of them may
I added a sale forum at the bottom of the index. Sale away lol.
viewforum.php?f=50
viewforum.php?f=50
I see you removed/edited your post. I caught this before the edit.ATPCR
Unread post 19 Dec 2024, 07:39
@Michael P. Crai8 Covers most all 98 fords including mustang v6, v8, cobra, lincoln town car, grand marquis and crown vic. To get my tachometer working again, could I use a 1998 Mustang PCM in place of the '99 Crown Vic PCM that I have now without any major wiring changes to the 99CV powertrain harness? I'm aware that there are a few pins to move around. Then I could sell off the 1999 Crown Vic P71 PCM to someone with a 1999
Crown Victoria with no tachometer.
By the way, separate topic. On my next 5.0 c-n-p conversion I will be using the 2003 Ford full size PCM. I just can't give it up to use on this first project.
Question. Is there appropriate place here on your forum for parts for sale or would you rather no one attempt to sell related parts, like PCMs or powertrain harnesses, here on your site?
