EEC V file conversion
Re: EEC V file conversion
Thanks for the updated files.
You could try Ghidra for digging around exe and dll.
https://ghidra-sre.org/
Usb sniffer or packet capture would allow looking at usb traffic.
The QH gives access to all of the ECU, so what is to be gained from the diagnostic subset??
Rfe is an rbase, you can likely find the value it holds in your msg file or you could look in lst for where Rfe is loaded with a value.
Look at code preceding your pasted snippet for where r26 is loaded with a value. An rbase could be set over a range but the jump bit will foil the plan due to +8 vs +8+2.
I guess nothing really there. I was just thinking about the active commands section to activate outputs from tunerpro maybe for diagnostic purposes I guess. I think that the addressing may be in the vehicle build file possibly. Not sure. A lot of the xml files seem to point to a vbf file.The QH gives access to all of the ECU, so what is to be gained from the diagnostic subset??
I will see what I can track down here. I do have Rfe defined in my lst file, not sure why SAD is not applying the value in this SUB. May be a bug I guess.Look at code preceding your pasted snippet for where r26 is loaded with a value. An rbase could be set over a range but the jump bit will foil the plan due to +8 vs +8+2.
Looks like it loads word 12a7, which is also GR_DS_TV, should I be looking at this subroutine without the label on the 12a7 address and as a value instead?
More like this? But instead of 12a7 add 8 to it to equal 12af?
Sxx92128_RZA082DA:
92128: f2 pushp push(PSW);
92129: a1,a7,12,26 ldw R26,12a7 TEMP1L = GR_DS_TV;
9212d: a1,2a,00,28 ldw R28,2a TEMP2L = 2a;
92131: 10,08 rombk 8
92133: ef,4f,b9 call 8da85 Sxx8DA85_RZA8E908 ();
92136: 11,3c clrb R3c TMP5L = 0;
92138: 01,26 clrw R26 TEMP1L = 0;
9213a: b3,01,21,01,30 ldb R30,[R0+121] TEMP6L = TP_REL_H;
9213f: b3,e4,10,31 ldb R31,[Re4+10] TEMP6H = VSBART_RT;
92143: 37,b0,18 jnb B7,Rb0,9215e if (FLG_SFT_IN = 1) {
92146: b3,fd,80,10,46 ldb R46,[Rfc+1080] TMP0L = [16db2];
9214b: 30,46,04 jnb B0,R46,92152 if (B0_TMP0L = 1) {
9214e: b3,e4,32,30 ldb R30,[Re4+32] TEMP6L = [112b2]; }
92152: b3,fd,81,10,46 ldb R46,[Rfc+1081] TMP0L = [16db3];
92157: 30,46,04 jnb B0,R46,9215e if (B0_TMP0L = 1) {
9215a: b3,e4,15,31 ldb R31,[Re4+15] TEMP6H = [11295]; } }
9215e: 39,2a,11 jb B1,R2a,92172 if (B1_TEMP3L = 0) {
92161: 3a,2a,10 jb B2,R2a,92174 if (B2_TEMP3L = 1) goto 92174;
92164: 3b,2a,30 jb B3,R2a,92197 if (B3_TEMP3L = 1) goto 92197;
92167: 3c,2a,02 jb B4,R2a,9216c if (B4_TEMP3L = 0) {
9216a: 22,56 sjmp 923c2 goto 923c2; }Code: Select all
92197: 65,08,00,26 ad2w R26,8 TEMP1L += 8;
9219b: 3d,ad,04 jb B5,Rad,921a2 if (FLG_SFT_UP = 0) {
9219e: 65,02,00,26 ad2w R26,2 TEMP1L += 2; } } } }
921a2: 45,6e,92,26,32 ad3w R32,R26,926e TEMP7L = 12a7 + 926e;
921a7: 46,32,fe,36 ad3w R36,Rfe,[R32] TMP2L = 1723e + [TEMP7L];
921ab: b0,30,38 ldb R38,R30 TMP3L = TEMP6L;
921ae: 91,10,a5 orb Ra5,10 SIGNDY = 1;
921b1: ef,a9,26 call 9485d SLU9485D_92C16_**YFn ();
921b4: c7,e4,2a,3c stb R3c,[Re4+2a] TV_RAMP = TMP5L;-
From your pasted example, it could be 12af or 12b1, depends on B5_Rad.
Add a couple lines to your comment file for the sum results of both.
Questioning your example, R26 is loaded with 0.
In this case it's 8 or a.
92138: 01,26 clrw R26 TEMP1L = 0;-
Missed when it cleared the word value, sorry about that. So it should be 8 or a depending on the result in b5_Rad then? Just to clear it up. So then I would add 8 to 926e to equal 9276 or a to 926e to equal 124ee than add the RBase value of 1723e to either of those results to find what is loaded into Tmp2l?
like this?
But I feel like that would be incorrect, because of the results? Because there is no s.0x204be? So what am I doing wrong? Sorry if these are stupid questions. Or maybe the RBase value in Rfe is not correct?
like this?
92197: 65,08,00,26 ad2w R26,8 TEMP1L(0) += 8; =8
9219e: 65,02,00,26 ad2w R26,2 TEMP1L (0)+= 2; } } } } =2
921a2: 45,6e,92,26,32 ad3w R32,R26,926e TEMP7L = 8 + 926e; = s.0x09276 or a + 926e = s.0x09280
921a7: 46,32,fe,36 ad3w R36,Rfe,[R32] TMP2L = 1723e + [TEMP7L]; s.0x09276 + 1723e = s.0x204b4 or s.0x09280 + 1723e = s.0x204be
Two things appear to be tripping you up.
Address mode for line 921a7, what do you make of that?
Data bank, once memory expansion is enabled and the data bank is set, which commands automatically get data from which bank?
The address mode is indirect. But I need to read up on what that means in this case. Also need to read up on memory expansion a bit more.
Ok, read up, post back if it still doesn't make sense.
Did you get this?
Something like this could go in CMT
926e + 8 = [9276]
19276: c8,13 word
1723e + 13c8 = 18606
926e + 2 = [9270]
19270: a4,13 word
1723e + 13a4 = 185e2
92197 # 0x08
9219E # 0x02
921A2 # [19276] \s19276\n
921A2 # [19270] \s19270
921A7 # [18606] \s18606\n
921A7 # [185E2] \s185E2
